Noise when key is off?
Old Apr 16, 2011 | 09:13 AM
JT250's Avatar
JT250
Why would the solenoid that the red and green lines come out of on the spyder be making noise w the key off?
Old Apr 16, 2011 | 09:17 AM
mueckster's Avatar
mueckster
That's a good question! Never heard of that before. Did you unplug it? It gets 12v power from the same fuse as the fuel bowl heater. I shouldn't be live with the key off. It is ground controlled by the PCM. Anything else on with the key off? What kind of noise is it making?
Old Apr 16, 2011 | 09:47 AM
JT250's Avatar
JT250
Yes there is a electric motor or something on the pass fennderwell that comes on every now and then w key off. This is my friends truck and it eats batteries.
Old Apr 16, 2011 | 09:54 AM
mueckster's Avatar
mueckster
Sounds like the power is not shutting off for the vacuum pump also.
Old Apr 16, 2011 | 10:07 AM
JT250's Avatar
JT250
Any ideas what would cause that?
Old Apr 16, 2011 | 01:17 PM
danskool's Avatar
danskool
Go Bills !
Water getting into the fuse panel?
Old Apr 16, 2011 | 01:36 PM
JT250's Avatar
JT250
He said he hasn't had any leaks where water has gotten in.
Old Apr 16, 2011 | 01:43 PM
bluescrew's Avatar
bluescrew
i bet hes gettin water in a spot he doesnt know about!
Old Apr 16, 2011 | 01:48 PM
JT250's Avatar
JT250
Its been going on for a couple of years and hasn't found ny water.
