hard to start after being driven
Old Nov 21, 2012 | 02:53 PM
Lilryan's Avatar
Lilryan
so the truck starts fine in the morning. but if i drive it, turn it off and then try to restart it, it cranks really slow. like the battery is dead or timing is too high. i checked base timing and it was 8-10 degrees advanced at idle. it cranks fine when it is cold, so i dont think it is the battery. what could it be. dont want to leave myself stranded waiting for the truck to cool off.
thanks
ryan
Old Nov 21, 2012 | 02:54 PM
Lilryan's Avatar
Lilryan
the truck is an 87 f350 with a 460 4 speed.
Old Nov 24, 2012 | 03:23 PM
Bobcat7's Avatar
Bobcat7
My van did that after being rebuilt. I assumed it was tight and fresh... it'll get better.
It was a poor starter plus the heat from the new headers- was stock ci manifolds.
All that combined....
Will/can advance auto etc. do an amp draw check?
Old Nov 24, 2012 | 04:18 PM
Lilryan's Avatar
Lilryan
My starter is new, but might be laying down on me when it gets hot. I would like to go to a newer mini starter, but i want to get my headers installed first to make sure i have enough room. For now, i will try to just replace the one I have under warranty and hope that helps the situation.
Old Nov 28, 2012 | 07:55 PM
ford4v429's Avatar
ford4v429
backing the timing off helps hot starts. if it never pings, youre not overly advanced, so might want to get adjustable vacuum advance so you can leave it retarded for easy starting, but advances back to normal once started... pull the coil power next time, see if its timing causing the slow cranking...if it cranks ok with no spark, need to figure out advance.
carbon deposits/hotspots can do it too, might think of seafoaming it or something...
Old Nov 28, 2012 | 09:00 PM
V10man's Avatar
V10man
I had this issue. What I did to fix it was change both battery cables to 2 guage from 4 guage and clean the terminals on the sellenoid. My cables were all jacked up anyways so it was needed.
Old Nov 29, 2012 | 08:59 AM
Lilryan's Avatar
Lilryan
Thanks for all the help guys. I bought new 4 gauge ground cables to make sure i had a good ground. I would have bought bigger but that is what the parts store had. I will try the coil wire the next time I have a problem. That is a great idea.
Bbaldeagle
Nov 4, 2014 06:18 PM
berlincam86
16
Jan 18, 2014 08:25 PM
QH rancher
Jul 8, 2009 09:33 PM
Beast12
Jul 14, 2008 07:45 PM
buzzard
13
May 14, 2001 03:44 PM
