Crazy electrical problems and P0500
Old Apr 12, 2011 | 12:26 PM
stefanlg55's Avatar
stefanlg55
Well yesterday i was working on my truck and accidentally doped a crowbar on the battery terminals( making contact with both). After that i drove the truck and immediately noticed that while i was driving my ABS brake light came on, O/D blinking, and my speedometer would jump from 0 - 110, my guage was showing that my RPM's were too high.
When the speedometer was making its way to 110 my engine was working but then when it began to drop down to 0 again my engine would immediately seem to stop working, My gas pedal never moved, it was as if my engine was kicking in and out with the speedometer causing a somewhat jerking motion.
Then if i turn my headlight on i cant use my turn signals, headlights seem extremely dim, but then my speedometer stops working and drops to 0.
Old Apr 12, 2011 | 06:57 PM
stefanlg55's Avatar
stefanlg55
Also the fog lights no longer work ive checked the bulbs they are good but they are not turning on.
Old Apr 12, 2011 | 10:07 PM
shorod's Avatar
shorod
If you haven't already, I'd try disconnecting the battery and leaving it disconnected for 10 minutes or so, then reconnect and see if at least a few of the items work more normally. Since you are getting a P0500 code from the ECU it seems likely that the ECU isn't horribly damaged.
What year is the Explorer?
-Rod
Old Apr 13, 2011 | 01:37 AM
stefanlg55's Avatar
stefanlg55
2000, but i dont think its the ECU, or the GEM
newandoldford250
May 12, 2016 04:48 PM
52 F1 Stocker
Oct 21, 2015 08:20 AM
KaiserKlauss
Jun 16, 2015 06:02 PM
Authenticraft
26
Feb 9, 2015 05:35 PM
50trucking
Sep 23, 2014 03:13 PM
