hpop fitting-o ring replacement question
Old Apr 12, 2011 | 07:48 AM
ccarrier's Avatar
ccarrier
my new hpop decided it wanted to start leaking from one of the high pressure fittings.
i bought the 3 o ring kit today (w/ loctite)
do i need to heat the fitting to remove it?
Old Apr 12, 2011 | 08:01 AM
Action4478's Avatar
Action4478
This One ?... Click here ...Replacement O-rings for Ford Diesel Engines
Old Apr 12, 2011 | 08:06 AM
ccarrier's Avatar
ccarrier
no, not the non serviceable plug.
im talking about the high pressure line fittings in the pump
Old Apr 12, 2011 | 09:30 AM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
I suppose that your new pump has the stock fittings and not the SD pumps (quick connect), rigth? if so, When I changed the o-rings I didnt heat them, I only used two 11/16" open wrenches to do it, its a PITA because is tight there but doable. good luck.
Old Apr 12, 2011 | 09:39 AM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Thumbs up
BTW I didnt use loctite in the fittings.
this link will help you if you have the "new" style of fittings.
http://www.dieselorings.com/docs/fullHPOP.pdf
Old Apr 12, 2011 | 09:48 AM
ccarrier's Avatar
ccarrier
i got it fixed, thanks guys
Old Apr 12, 2011 | 10:02 AM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Question
Please could you explain more, and maybe answer my questions?
Old Apr 12, 2011 | 10:11 AM
ccarrier's Avatar
ccarrier
one of the o rings on the hpop line had split in 2 and was causing long cranks and an oil leak i chased for a week
went to ford this morning and bought new o rings and replaced them
and i have a modded 17* pump but i used my factory obs fittings.
Old Apr 12, 2011 | 10:17 AM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Question
Ok, thank you. So you dont heated them and you dont use loctite, right? and just curious what was the o ring that had split in two? the one to the front or the rear one? In mine the frontest was the bad one.
Old Apr 12, 2011 | 10:26 AM
ccarrier's Avatar
ccarrier
i used a tiny drop of loctite(just in case) and it was the oring closest to the fuelbowl
Old Apr 12, 2011 | 12:05 PM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
ok, thanks again, I got that.
ScaldedDog
Sep 17, 2011 07:27 PM
baja2000
19
Jun 19, 2011 10:12 PM
FuzzieLogik
104
Jan 25, 2010 01:01 AM
tnardo
31
May 15, 2009 08:43 PM
