extended U Bolts
Old Apr 11, 2011 | 10:48 PM
old_lynrd's Avatar
old_lynrd
extended U Bolts
hey guys i am stacking 2 stock blocks on the rear leaf springs of my 90 f150, where can i get U bolts that are long enough to work? thanks for any help!!
Old Apr 11, 2011 | 11:40 PM
mean green 91's Avatar
mean green 91
not a good idea.. get bigger springs or at least flip the shackles.. do it right
Old Apr 12, 2011 | 08:39 AM
jas88's Avatar
jas88
I got mine on eBay from this guy:
http://cgi.ebay.com/ebaymotors/4-REA...Q5fAccessories
Old Apr 12, 2011 | 09:07 AM
old_lynrd's Avatar
old_lynrd
Originally Posted by jas88
are they long enough to hold the 2 blocks together?
Old Apr 12, 2011 | 09:10 AM
old_lynrd's Avatar
old_lynrd
thank you for your input i appreciate the advice, but even aftermarket lift kits use blocks to lift the rear, so i do not see why this is not right? its better than some of my friends who make lift kits out of wood or whatever scrap they have laying around, plus its a 21 yr old truck i dont want to spend $600+ on a actual lift kit, i got the truck for free soyou can understand where i am coming from..
Old Apr 12, 2011 | 09:21 AM
zxwut?'s Avatar
zxwut?
Do the shackles. You are going to crack stacked blocks.
Old Apr 12, 2011 | 09:26 AM
Diesel_Brad's Avatar
Diesel_Brad
Get a tape measure and measure your stock u-bolts(length and axle diameter) then add the height of your second block. NAPA, Advanced, Auto Zone and the like all stock u-bolts. You will most likely need the same length ones a F350 uses.
I am not a fan of stacking blocks, try and find 1 block for the total height.
F350 use 4"
F250 use 2.5"
Old Apr 12, 2011 | 09:51 AM
RJR99SS's Avatar
RJR99SS
They use lift blocks, but they're not using two stacked on top of eachother.
Blocks act like a lever arm when you start them longer and longer. Read up about axle wrap. Well, that effect is magnified the more blocks you put on there. The more blocks you put in, it exponentially increases the amout of stress you put on the spring and the driveline.
So...go ahead man, but the next time you do a hole shot and you break a spring, or blow a u-joint up....dont say i didnt tell you so.
Old Apr 12, 2011 | 09:55 AM
White Max's Avatar
White Max
Agreed. If you're going to use blocks to lift the rear, at least get the correct blocks for the height you want. Stacking blocks is a bad idea.
Old Apr 12, 2011 | 12:52 PM
Diesel_Brad
Actually YOU are wrong. All of the suspension companies out there give you a block to STACK on top of your stock block unless you go with replacement springs or add-a-leaf
Old Apr 12, 2011 | 03:10 PM
94BigRed's Avatar
94BigRed
Anybody will sell you anything as long as people will buy it. Just because you can get one doesn't mean you should use it. Stacked blocks are very dangerous, even if they're only on the back. Just a little bit of stretch in the u-bolts, and that happens, and those blocks can kick out on land you on your lid in a heartbeat. or a barrel roll. or a cartwheel.
At any rate, if your as little a fan as I am of truck gymnastics and breakage, don't do a block stack. Flip the rear shackles. Its much safer, adds articulation, and costs as much as grade 8 bolts.
Old Apr 12, 2011 | 06:18 PM
old_lynrd's Avatar
old_lynrd
so back to the original question....where can i get longer U bolts? i called autozone and all they had were stock size, they said 250 and 350 were same as 150,
Old Apr 12, 2011 | 06:32 PM
Diesel_Brad
NO. F150 u-bolts are different then F250 and also different than F350
F350 u-bolts are approx 13.5" long
F250 u-bolts are approx 10" long
I dont have a F150 other wise I would give your those measurments
Old Apr 12, 2011 | 06:36 PM
White Max's Avatar
White Max
If you have a farm/tractor supply type store near you, they will typically carry them.
Old Apr 12, 2011 | 06:39 PM
Diesel_Brad
