97 explorer drivers side window
Old Apr 11, 2011 | 01:17 PM
ap4u06's Avatar
ap4u06
the master switch will let the other 3 windows down, but does not let the drivers side down. I have tried to beat on the panel with the switch to see if the motor is bad, and i get nothing....any ideas what this could mean?..
Thanks,
Ap4u06
Old Apr 11, 2011 | 02:15 PM
shorod's Avatar
shorod
Have you checked the switch assembly to see if it is providing power to the motor assembly? If you end up pulling the door panel, you should also check for power at the power window motor. With couple of test leads you could try to power the window motor to see if it operates both directions as well.
-Rod
abrewer
Mar 21, 2012 07:31 AM
CWO-06250
Feb 16, 2012 03:47 PM
ap4u06
Mar 18, 2011 06:06 PM
cope9079
Feb 23, 2009 06:59 AM
ap4u06
Jan 5, 2008 04:37 PM
