97 explorer no heat
Old Mar 17, 2011 | 10:30 AM
ap4u06's Avatar
ap4u06
97 explorer no heat
turn the heat on and all i get is cold air blowing what could be wrong it worked last winter?
Old Mar 17, 2011 | 12:48 PM
shorod's Avatar
shorod
Does the temperature gauge work and indicate that the engine is getting up to temperature?
Assuming it does, and assuming you have the manual HVAC controls (*****) rather than the electronic climate control (buttons) I'd suspect you have a vacuum issue. If you are able to select the vents that the air comes from and that seems to be working properly, then check the operation of the water control valve under the hood in the heater hose.
-Rod
Old Mar 18, 2011 | 06:06 PM
steve(ill)'s Avatar
steve(ill)
check if the control **** slips on the shaft, then check the blend door area. temp is electric... air duct routing of air is vacuum.
https://www.ford-trucks.com/forums/9...-question.html
rod250
Feb 4, 2014 12:14 PM
baller9409
Jul 24, 2012 10:34 PM
captntim
Jun 3, 2006 02:18 PM
cobraguy
Dec 30, 2001 12:59 AM
reroy
Dec 9, 2000 08:09 PM
