power window
Old Mar 20, 2012 | 05:08 PM
abrewer's Avatar
abrewer
power window
Ok guys looks like everybody here is a lot smarter than me so ill let u have a shot. Rear passenger window will only go up. I tried new motor, same problem, swapped switch with other back door the problem stayed on the same side. Drivers main switch to that rear window does same thing, up but not down. Any advise would be greatly appreciated, thanks.
Old Mar 20, 2012 | 05:10 PM
abrewer's Avatar
abrewer
2001 excursion 4wd.
Old Mar 20, 2012 | 06:55 PM
Jmatthews's Avatar
Jmatthews
is a BAAAD MAN
Do you hear the window motor coming on when you hit the button? Maybe a loose wire.
Old Mar 20, 2012 | 07:15 PM
abrewer's Avatar
abrewer
I check it with a meter and get 13v when I push the up on either the back door switch or the driver switch. But nothing when i push down. I just got done cleaning all the contacts on the main driver door buttons still no change.
Old Mar 20, 2012 | 07:16 PM
abrewer's Avatar
abrewer
When i hooked up a new motor it would spin when i hit up on either switch but not down
Old Mar 20, 2012 | 07:22 PM
Jmatthews's Avatar
Jmatthews
is a BAAAD MAN
It sounds like a wire in between the switch(s) and the motor is loose or pinched. Can you do a continuity test?
Old Mar 20, 2012 | 07:25 PM
abrewer's Avatar
abrewer
At this point I can try anything
Old Mar 20, 2012 | 07:28 PM
abrewer's Avatar
abrewer
I ran the new motor by itself not attached to the door.
Old Mar 20, 2012 | 07:40 PM
abrewer's Avatar
abrewer
Any idea which wires I should test
Old Mar 20, 2012 | 08:33 PM
Jmatthews's Avatar
Jmatthews
is a BAAAD MAN
Check out this thread https://www.ford-trucks.com/forums/9...al-help-2.html see if that helps.
Old Mar 20, 2012 | 09:23 PM
wallz's Avatar
wallz
Same one I had problem with last summer. I changed switches from other side, changed motor from front door, nothing worked.
Ended up being broken wires in the wire boot that you see covering the wires when door open. That door is used more then the other side, but still beyond me why 1 wire completely cut, and 2 frayed.
Also tight spot to work in to crimp new connectors on, and heat sink, tape in. Have fun.
Old Mar 20, 2012 | 09:33 PM
Jmatthews's Avatar
Jmatthews
is a BAAAD MAN
Cool sounds like we have a winner.
Old Mar 21, 2012 | 07:31 AM
abrewer's Avatar
abrewer
I will check the wires first thing in the morning thanks. I'll let u know.
Bigtom04
Nov 3, 2015 10:42 PM
sparks44
Jan 29, 2011 07:37 PM
jackiegibson
Jun 24, 2010 06:57 PM
Taboo
Jul 24, 2007 12:24 PM
Dutch123
1978 - 1996 Big Bronco
Nov 22, 2004 09:32 PM
