1978 - 1996 Big Bronco
cluster
Old Apr 9, 2011 | 09:26 PM
njneer1's Avatar
njneer1
cluster
OK ....I pinned out the guages and ....I have power and ground to the cluster....I ground the leads to the oil pressure, fuel level and temp......no movement from the guages ??....still not convinced my cluster is bad cause I have no guages working !!??!! HELP !!
Old Apr 9, 2011 | 11:32 PM
greystreak92's Avatar
greystreak92
Negative (ground) is common to all of the gauges so assuming none of the internal cluster wiring (circuit board traces) are damaged you should be ok there. The power feed for the cluster is Fuse #18. The RED/YELLOW wire meanders all over the place finally wending its way up to pins B5 AND A13 in the cluster.
Old Apr 10, 2011 | 08:04 AM
njneer1's Avatar
njneer1
Thanks ....I'l double check on both of those but I know I have power on R/Y in the right side connector. ......and the ground is good....Doesn't it seem unusal to lose them all ? or is it a common failure ?
Old Apr 10, 2011 | 06:51 PM
greystreak92
Yes, it does unless there is a broken trace on the dashboard circuit board. All of my electrical diagrams show the RED/YELLOW as common feed for the gauges along with the ground. And its even less likely that all of the triggers for the gauges have failed.
nstueve
29
May 21, 2017 06:28 PM
Goinnuts
Dec 2, 2015 03:12 AM
dtony
Jan 23, 2006 09:43 AM
brown 4x4
Electrical Systems/Wiring
Jun 12, 2004 06:23 AM
yakole
Sep 15, 2003 04:00 PM
