She's Screeching. WTH?
Old Apr 8, 2011 | 08:40 PM
LittleRadio's Avatar
LittleRadio
Question She's Screeching. WTH?
My 2000 Exc V10 2WD started making a screeching, metallic noise when i turned a corner today. The noise was not speed or engine rpm dependent. Not brakes, either, because i coasted in drive and neutral and it persisted, but got more pronounced when i turned the wheel.
I recently had the power steering fluid replaced. Coincidence? Nothing dragging beneath either.
What do you guys (and gals) think?
Old Apr 8, 2011 | 08:41 PM
LittleRadio
Exclamation
And it is still screeching.
Old Apr 8, 2011 | 09:38 PM
69oiler's Avatar
69oiler
wheel bearing?
Old Apr 8, 2011 | 09:45 PM
Moto Mel's Avatar
Moto Mel
Is the noise coming from the pump? Or where?
Old Apr 9, 2011 | 07:08 AM
LittleRadio
I'm thinking its a wheel bearing or hub assembly. After i filled up with gas, I turned the wheel hard right to pull out of the station and I felt a "slip" in the front wheels. Like the lug nuts on the tires were loose and the wheels shifted under the load.
I'm pretty sure the wheels' lugs are tight (I'll check this am), but jeezopeet... Bad bearings? The truck has only 35,000 miles on her!
Old Apr 9, 2011 | 08:15 AM
Moto Mel's Avatar
Moto Mel
That sounds like the hub was never properly torqued. Just jack it up and shake the suspected wheel, you should be able to find it without a complete tear down. If it is the hub I think it would be a good idea to change both, just as a precaution.
Old Apr 9, 2011 | 11:36 AM
LittleRadio
Jacked up tire and Grabbed top and bottom of front tire and there's play. Bad bearings, right? Because hub assemblies are only on 4x4s, right?
Old Apr 9, 2011 | 11:42 AM
Rickx's Avatar
Rickx
Does your power steering pump howl if you turn the wheel to the max? While moving?
Sitting still?
Old Apr 9, 2011 | 11:44 AM
LittleRadio
Now. PS pump doesn't cause noise. ONly when my front wheels are turning, do I hear the screeching. I guess I'm heading out to O'Reilly (in my wife's car) to buy a set of front bearing assemblies...
Old Apr 9, 2011 | 12:51 PM
Moto Mel's Avatar
Moto Mel
If there is more than just a little play, yes. You might have found the problem.
Old Apr 9, 2011 | 11:46 PM
ke6zmy's Avatar
ke6zmy
Does not replacing a wheel bearing require the R/R of the ball joints? You may want to make sure you have the tools for this, too, before you start.
Old Apr 10, 2011 | 01:12 PM
vinnyt123n's Avatar
vinnyt123n
My V10 used to do the same thing. I sent it to the dealership when I needed to get new brakes and I guessed they fixed that to because it doesnt do it anymore.
87mark7lsc
1978 - 1996 Big Bronco
Aug 21, 2013 07:11 PM
99Exp
18
Sep 17, 2009 12:02 PM
bmacky14
1997 - 2003 F150
Feb 17, 2009 03:45 PM
romanwright
20
Jun 9, 2004 08:45 PM
cwh82
Oct 30, 2003 04:04 AM
