Steering Noise
Old Apr 26, 2004 | 08:14 AM
romanwright's Avatar
romanwright
Steering Noise
I have an '86 Ford F150 5.0 and just within the past month I started getting a loud screeching noise when I turn the wheel left or right. The power steering fluid was low so I topped it off but I am still getting the same noise. Any ideas on what else to check out?
Old Jun 8, 2004 | 11:17 AM
dennhop's Avatar
dennhop
It's possible that your power steering pump is going out. I know a couple of buddies that they had to replace their pump when it started doing that...
It does it when you crank the wheel all the way left or right?
I can't think of anything else off the top of my head.
Old Jun 8, 2004 | 11:26 AM
Stokes's Avatar
Stokes
get some of that Lucas oil stuff, and if that doesnt do it, just go to the local scrap yard and get another $10 pump!
Old Jun 8, 2004 | 01:19 PM
82f1504x4's Avatar
82f1504x4
sounds like every other ford power steering pump mine does the same and so does most older fords i come in contact with some people say if it stops whining then you have a problem replace the pump with a saginaw they are much better
Old Jun 8, 2004 | 02:03 PM
fai4g63's Avatar
fai4g63
Check your power steering belt for proper tension. They will squeel real loud when they slip.
Old Jun 8, 2004 | 05:47 PM
Stokes's Avatar
Stokes
my theory on fords little wussy pumps, is they put more load onto the belt to squeel rather than a stock saginaw that moves with ease.
Old Jun 8, 2004 | 07:14 PM
Nightrain's Avatar
Nightrain
Mine does the same thing. It will do it at idle while I'm sitting still when I turn the wheel to the left or the right. I had my dad do it once while I watched the pump and the belt wants to squeal. Any ideas on how to fix it? Do I need a new pump? What is this "Saginaw" pump that everyone is talking about? Will it bolt right in?
I'm really wanting to get this fixed myself...
Nightran
Old Jun 8, 2004 | 09:29 PM
fai4g63's Avatar
fai4g63
I never understood why ford used the saginaw pumps in vans while the trucks got the ford pumps. If your belt is tight and still squeels or has been slipping for a while replace the belt, more than likely its glazed.
Old Jun 8, 2004 | 10:46 PM
Nightrain's Avatar
Nightrain
Okay. Thanks for the tip fai4g63. I might do that. It's worth a shot anyway. Nonetheless, a new pump is only $35. If I get a sagniaw pump, will I have to ask for one on a van or what? What would be the request on the saginaw?
Thanks again.
Nightrain
Old Jun 9, 2004 | 09:52 AM
Stokes's Avatar
Stokes
depending on what motor you have, the easiest thing you can do is find the pump/bracket/hoses from a van that had PS and the same motor, you can just buy a new pump and the other stuff seporate, but then you have to go through the hassle of putting the pulley onto the pump (MAJOR PITA, bad juju) this way you end up with a strong PS pump anyways, especially if you are running bigger tires, the Saginaw is almost a must.
Old Jun 9, 2004 | 10:06 AM
Nightrain's Avatar
Nightrain
Thanks Stokes. My truck has the 300 I6. Did some Ford vans from the 80's come with this same engine? I don't really know if there are any vans in the yards around here. I'll have to call around and check. If I had to buy a new standard Ford pump, will it still do the squealing thing that it does now?
Thanks .
Nightrain
Old Jun 9, 2004 | 10:54 AM
KenB's Avatar
KenB
Romanwright, just how low was fluid, and can you see where it's gone to (leak)?
Also, at what point in turning do you hear the squeal?
Has pump ever been off/unbolted?
If yes, could have air in system.
Agree with belt is first culprit to check out.
Old Jun 9, 2004 | 12:05 PM
Stokes's Avatar
Stokes
Thanks .
Nightrain
yep, lots of vans Around with the big6, if you cannot find anything, i could probly sell you one, i have an extra setup from a 87van, you might be able to just slap a V-belt pulley on it and call it good. otherwise, interested in just converting your system to a serantine belt? lol theres a way to get rid of the anoying belt sqeak for good.
Old Jun 9, 2004 | 12:07 PM
Nightrain's Avatar
Nightrain
What are you asking for the system that you have from the 1987 Van?
Nightrain
Old Jun 9, 2004 | 12:11 PM
Stokes's Avatar
Stokes
Nightrain
ill try and get a number to you soon, i should have mentioned that it will be a little while till i can get to it, i havnt even had time to get started on my D60/eaton axle swap yet.
