Key and code
Old Apr 14, 2011 | 06:50 AM
shotgunz's Avatar
shotgunz
Originally Posted by shortride
Some locksmith shops can program Ford keys.
From everything I have read, I don't think they can create a unique PATS key - they can only duplicate an existing (already programmed into the PATS) key. Thus you still wouldn't be able to create your own keys.
Some Ace Hardware stores offer the same service.
Old Apr 14, 2011 | 11:38 PM
mrbill1943's Avatar
mrbill1943
I have a truck without the keyless entry. I had a key made, one of the flat one, so I can get into the truck if I lock my keys in. If I lose my keys I am out of luck.
Old Apr 15, 2011 | 05:33 AM
shortride's Avatar
shortride
I use one of those magnetic hide-a-key containers hidden somewhere on the truck.
Old Dec 16, 2021 | 12:04 AM
Hidden Hollow Farm's Avatar
Hidden Hollow Farm
4th Gear
On my 2010 f250, I think that there is a simple solution to your problem. If you remove the fuse box cover on the passenger side below the glove box, then remove the cover on the passenger side door jamb at the same level and then the cover that is left where the fuse box was, The 5 digit key code should be on a white sticker on the back side of the printed circuit panel that will be exposed. There are two self tapping 7mm hex screws that hold the panel in place.. You can carefully pull the panel out far enough to look behind it with a mirror.
Airborne Cajun
Apr 27, 2019 08:04 AM
crozz
Iowa Chapter
Mar 7, 2017 12:23 PM
THaywood
Sep 12, 2012 06:16 AM
tjc transport
Sep 5, 2010 07:52 AM
dukman22
Feb 5, 2007 07:48 PM
