explorer door key-less entry code location
Old Sep 2, 2010 | 06:00 PM
tjc transport's Avatar
tjc transport
i ain't rite
one of the kids in work just bought a newer explorer, but did not get the key-less entry code.
does anyone know where it is located in the vehicle??
i know on the cars it is on the passenger trunk hinge, but i looked around in the explorer a bit and could not find it on the door hinges.
Old Sep 2, 2010 | 09:33 PM
shorod's Avatar
shorod
You need to know the model year and style as it's in different locations depending on model year, 4-door, or Sport Trac.
I have to believe that if you searched this forum you would find the info. It's even a sticky on one of the other forums I frequent.
If you don't find it doing a search, post back with the requested information. It will either be on the driver's side kind of above the rear wheel but inside the trim panel, affixed to the Remote Anti-theft Personality (RAP) module, on the passenger side behind the second row door, or above the glove box viewed from the removed defrost grill.
-Rod
Old Sep 5, 2010 | 02:20 AM
pap999's Avatar
pap999
On my 01 Sport Trac, the code could be seen in the cavity behind the storage lid in back of the rear seat. You have to shine a light back there to see it, but it's there.
Old Sep 5, 2010 | 03:03 AM
zecolleman's Avatar
zecolleman
In my 2004 is right side behind rear door inside the panel just down under the seafty belt it´s written on the computer. You have to loosen the panel I could see it with out take it all off.
Old Sep 5, 2010 | 07:52 AM
tjc transport
i ain't rite
ok, thanks guys. i will look on tuesday when he comes back to work.
i actually did try a search before i posted this thread, and the only thing that came up was a thread from 2003 about how to tell if the explorer had keyless entry.
jasnjen
28
Dec 7, 2024 03:47 PM
Airborne Cajun
Apr 27, 2019 08:04 AM
FordTruckfan89
Aug 28, 2016 03:52 PM
WyoX
Mar 27, 2016 10:08 PM
bdalexan
Aug 30, 2003 12:25 AM
