2000 ed bauer explorer rear end problem??
Old Apr 7, 2011 | 01:17 PM
sharpcar's Avatar
sharpcar
thanks for stoppin in and helpin me out on this one i have 2000 explorer 4x4 that the rear end seams like it kinda locks up at turns only??it makes the front of the truck kinda feel like its wheels are gonna cave in at turns only??what gives i thought maybe ball joints or axles in the front are gone but a mechanic checked it out and saidm something about rear lock up etc...can any body give me info on what i can do without spending a ton of money on her???the switch on dash has auto hi and lo would this make it a awd???any info is gladly appreciated thank you ...
Old Apr 7, 2011 | 02:19 PM
aquanaut20's Avatar
aquanaut20
That would make it a ContolTrac, the transfer case is by defect in 2 wheel drive, when the controller senses slippage (differential between the front and rear tires), an electro mechanical clutch in the T/C activates, providing power to the front wheels (feels chunky on dry pavement, especially on turns). When the slippage is rectified the front power is deactivated, making it "Automatic".
If the front and rear tires are not equal in diameter the T/C will activate.
There are 2 hall sensors in the T/C which pick up metallic dust, causing them to malfunction. Drain the T/C (remove the fill plug first), remove and clean the Hall sensors, inspect for cracking (replace if defective), refill with clean ATF... Philip
Old Apr 8, 2011 | 08:21 AM
sharpcar's Avatar
sharpcar
thanks for the input on this one im gonna get dirty this weekend with her im gonna check the tires make sure there all the same size i know that there mis match tires and the front seem a little worn im gonna check u joints too cause i do also hear a clank from drive to reverse also and check those sensors you mentioned on the t/c i will keep u informed and thanks again for your input its gladly appreciated
chris2888
Jan 25, 2016 09:15 AM
Greatcarsx4
Nov 30, 2014 10:59 PM
Country_boy_2007
Dec 4, 2010 08:40 PM
redskinloyal
Aug 28, 2008 05:59 PM
gila_dog
Sep 8, 2007 01:45 PM
