04 explorer
Old Apr 8, 2011 | 09:05 PM
ap4u06's Avatar
ap4u06
04 explorer
i have an 04 explorer and while driving the rear end sounds like a jet engnine taoff. Any help would be appreciated..
Old Apr 9, 2011 | 08:30 AM
steve(ill)'s Avatar
steve(ill)
if it starts at 5 mph and gets louder as you go, and when you back off the trottle it still does it, then its a bearing. Most common would be wheel bearing. Least common would be piniion inside the differential..... NOW if it starts out slilghtly after 30 MPH, but you really hear it about 60-65 MPH, then back off the throttle and see if it goes 100% away.. IF there is NO noise when coasting, and the noise seems to also go away when you get up to 70-75 mph, then its probably gear mesh noise... which one ?
Old Apr 9, 2011 | 08:33 AM
steve(ill)'s Avatar
steve(ill)
https://www.ford-trucks.com/forums/1...rear-diff.html
