Removing Rust Stains on Wheels
Old Apr 5, 2011 | 03:30 PM
mantta's Avatar
mantta
I have a 2010 F-150 Lariat and from the salted snow and slushy roads I have rust stains on the wheels. It is not severe and I dont think the wheels are steel but I would like to remove the rust stains without damaging the wheels, any suggestions?
Thanks!
Old Apr 5, 2011 | 04:58 PM
Beechkid's Avatar
Beechkid
I would try a solution of baking soda & water-
Auto paint supply stores also sell (or have access to) iron oxide removal/neutraling solutions for paint
Old Apr 5, 2011 | 09:06 PM
Fred Smedley123's Avatar
Fred Smedley123
Oxalic Acid for steel , Neverdull for AL.
Old Apr 5, 2011 | 10:20 PM
PSYCHO_MIKE's Avatar
PSYCHO_MIKE
the works works
Squirt some "The works" toilet bowl cleaner on it and let it sit for 45 seconds then rinse. I purchased an old truck that sat under a rusting fire scape for two years in downtown Pittsburgh pa. After two years the paint was covered in rust stains from the fire escape above. Two bottles of "The works" and the paint looked new again. This won't let you down and you'll be amazed at how well it works.
Old Apr 6, 2011 | 09:28 AM
Beechkid's Avatar
Beechkid
If the rims are coated, do not apply any corrosive product or rub with never dull- only use products designed for application on paint
Old Apr 6, 2011 | 04:02 PM
mantta's Avatar
mantta
It has the standard wheels that come on a Lariat, not painted. I will try to attach photo.
Old Apr 6, 2011 | 06:33 PM
Beechkid's Avatar
Beechkid
Thos eare either powder coated or sprayed with a baked on enamel.....DO NOT USE ANY CORROSIVE PRODUCT!!!!!
Try the water baking soda mix, then if that doesn't do it make a trip to the auto paint supply store...they will have what you need to safety remove and neutralize any residue
Old Apr 6, 2011 | 06:43 PM
Killer RC's Avatar
Killer RC
A Medium polish will fix it safely. (not a wax or compound. It has to say Polish) Rub on by hand and work it. If its really bad you can add a Mothers PowerBall to the mix.
wmclark43
Appearance & Dress-Up
Jul 11, 2016 03:50 PM
cpsummitx
Dec 6, 2015 09:16 AM
mantta
2009 - 2014 F150
Feb 28, 2012 07:36 AM
stylin86f150
Oct 10, 2010 11:56 AM
Ruckus
2004 - 2008 F150
18
Jun 18, 2005 08:42 PM
