Doors off?
Old Apr 5, 2011 | 08:26 AM
patrickdemart's Avatar
patrickdemart
Doors off?
I have a 95 f150 regular cab. Had the idea of takin the doors off or puttin some tube doors like a jeep. Has anyone done it????
Old Apr 5, 2011 | 06:50 PM
StumpPullerF1's Avatar
StumpPullerF1
Seen a few broncos of our gen with them. Look pretty cool with a sas and built to crawl. I dont know if it would look cool with a semi stock truck.
Old Apr 5, 2011 | 07:46 PM
CWPottenger's Avatar
CWPottenger
Might be cool. I would want to be able to reinstall normal doors for the road if it was a dual purpose truck.
Old Apr 5, 2011 | 08:43 PM
Elderstarr's Avatar
Elderstarr
Did a lil' searching for ya...
http://www.pirate4x4.com/forum/showt...ght=tube+doors
Tube Doors I made for my bronco - Pirate4x4.Com Bulletin Board
Exploder gets tube doors. - Pirate4x4.Com Bulletin Board
Personally, I like how they cut down the stock doors instead of the tube doors.
Are you doing this just for visibility offroad? Or for extra ventilation in the summer?
Elderstarr's Avatar
Elderstarr
double post
Old Apr 5, 2011 | 09:14 PM
Wynn96's Avatar
Wynn96
Have fun re-aligning them.
Old Apr 5, 2011 | 09:32 PM
patrickdemart
Mostly for the summer. Thought it'd be fun to drive around but i don't know about the laws in va if I could do it.
Old Apr 5, 2011 | 10:33 PM
zxwut?'s Avatar
zxwut?
I've seen half door kits for the Broncos, so it should be a straight swap.
Old Apr 5, 2011 | 11:01 PM
CJM8515's Avatar
CJM8515
Best set I ever saw was made for a toyota. They took some manual crank window doors and removed the window, then took a air grinder and cut the door down lower, then welded a new piece on top to close the hole. Then they got someone to make them some convertible type plastic windows that snapped on.
Old Apr 6, 2011 | 01:16 PM
1lilredwagon's Avatar
1lilredwagon
I just did this with my buddy on his bronco, you have to drill out the knurled end of the door pin with a right angle drill then knock the pins out. Cut all the wires apparently if there are any colors duplicated it doesn't matter because rich didn't have any problems using a 12 pin and a 6 pin molex connector on each door and matching colors. Then drill out the hinges to 3/8" you will have to remove the upper door side hinge to drill it straight. Use four 4.5" X 3/8" bolts and taper the bottom 3/4" so they will fit back in easily. Reinstall the door hinge by matching up the paint marks, grab a buddy and reinstall the door. The hinges didn't require any adjustment and they were remarcably tight.
hvphotog
Feb 2, 2017 01:37 PM
Atkinsapproved
2009 - 2014 F150
Oct 14, 2016 04:57 AM
lhud
Aug 15, 2015 03:08 PM
jchosler
Feb 28, 2011 01:02 PM
jefxxo
Jul 28, 2009 09:46 PM
