Broken door handle
Old Feb 24, 2011 | 08:45 PM
jchosler's Avatar
jchosler
Broken door handle
I ripped off my door handle on the driver door interior side. Where can I find a good replacement?
Old Feb 24, 2011 | 08:46 PM
fordpride's Avatar
fordpride
Orielly's has them like 13.00 bucks
Old Feb 24, 2011 | 08:49 PM
fordpride's Avatar
fordpride
Take that back 7.00
Dorman 77178 - Interior Door Handle | O'Reilly Auto Parts
Old Feb 24, 2011 | 08:50 PM
RRranch's Avatar
RRranch
Make sure you take off the part that it bolts to and see if the door is cracked where the bolt goes through. I explained how I fix those in another thread just in case. Any parts place should have the handle in the help section. Adjust the door striker and hinges too. They break for a reason.
Old Feb 24, 2011 | 08:53 PM
fordpride's Avatar
fordpride
yup mine broke cause the cable was streched out easy fix just twist the cable the way it was already twisted to take the slack out
Old Feb 25, 2011 | 12:31 AM
bad12jr's Avatar
bad12jr
I'm going to go ahead and tell you. You are gonna get real good at changing them now. I've broken 5 between 2 trucks in the last 2 years all in the winter. I don't think the dormans hold up as well in the cold. That's what all mine have been.
Old Feb 25, 2011 | 04:01 AM
excavator's Avatar
excavator
all 3 of my trucks broke at the door frame. The latch was still good but the bolt ripped through so I hit the frame metal flat and then mig welded the latch back in place on all 3 trucks and never had any other issues.
Old Feb 25, 2011 | 06:51 AM
Neal 97 250's Avatar
Neal 97 250
X2.
See the other thread. I had to do that too.
Old Feb 25, 2011 | 07:04 AM
RRranch's Avatar
RRranch
You are supposed to adjust the slack in the cable by bending the tap it attaches to on the door handle end. New cables are cheap too if it's really stretched or broken but more often than not the problem is a warped or cracked door where the handle bolts to it. Also people using the wrong lubricants on the latch screws them up. I wouldn't use anything wet, like grease or oil. It just attracts dirt and gets in the lock motor causing problems. use graphite spray or something that dries completely.
Old Feb 25, 2011 | 07:14 AM
rodneywar's Avatar
rodneywar
what about using lithium grease thats what i use for the door mechanisms
Old Feb 25, 2011 | 07:25 AM
RRranch's Avatar
RRranch
If it's wet then it will attract dirt and there is no good way to clean it without taking the door completely apart. Dirt is what tears these doors up. In the army we were only allowed to use graphite and I never saw a loose door on any of our trucks. Some of them were 50 years old too. Schneider has the same policy. They hand out graphite spray by the case to mechanics.
Old Feb 28, 2011 | 01:02 PM
erl_berner's Avatar
erl_berner
Go for some motorcyle cable lube, it's dry graphite after the carrier juice evaps. Comes in a bottle with a needle applicator, easy to lube latch/handle parts and the cable too!!
GN1220
Jul 25, 2018 08:38 AM
sweet55
20
Jan 10, 2018 10:32 PM
troverman
Feb 17, 2017 03:17 PM
AZAV8
Ford Truck Parts for Sale
Feb 3, 2016 12:33 PM
Roger C
Nov 30, 2015 01:20 PM
