Thanks seth it is good info on the hood spears but what about the F2 emblems? it would seem that a simple flat plate with a hole and the slits cut in the flat sheet should hold it. Sorry not the best explanation. Basically you push the pin through pushing up the two sides that then grab the post not letting it go back out. Hope this makes sense.
jim
I have about three or four possible stores here. i will probable go to my Car Quest first and then to a couple of others. There is one that I know carries a lot of body shop stuff.
thanks
jim
