I was poking around under the hood yesterday and noticed oil around
the plug @ the oil pressure sensor on dr. side front oil galley.Pulled it and
it was full of oil,is this one the icp? Truck is running fine, but want to fix
it before trouble. The truck has always had a hitch when starting, if I
turned the key and waited a certain amount of time(20-30 sec) it starts
fine too short or too long and it needs to crank a little longer to fire.
Would this be why? 02 with 200k no mods just maint.
Tried to post this but didn't work so I hope it doesn't go 2x
Thanks Jeff
The truck has always had a hitch when starting, if I turned the key and waited a certain amount of time(20-30 sec) it starts fine too short or too long and it needs to crank a little longer to fire.
This problem sounds to me, like a fuel pressure problem. The fuel pump comes on when you turn the key on. After 20 seconds, it turns off. Without proper fuel pressure, the truck would take a while to start. As soon as the pump turns off, my fuel pressure drops like a brick.
The glow plugs would also cool down, after running their cycle. On a cold engine, they should stay on for two minutes though.
As far as the ICP goes.... If there is oil in the plug, it's time for a new one..
My ICP has been moist around the connector for about 1-1/2 years now and 20k miles. My truck runs fine.
In your case the leak might be around ICP sensor (o-ring going bad), but if there is oil in the sensor connector (oil leaking through the sensor) then it is time to change the sensor. A quick check is to remove the sensor connector and start the motor. If there is oil comng out of he top of sensor it is leaking through it. If there is oil leaking through the sensor it cannot accurately read the pressure.
Edit: If it is leakng from around the sensor the o-ring should be replaced.
Just an update, I replaced the ICP and put in HPx, The idle is smoother and
so far starts seem better. Will check mileage, but I dont know if that would change
