AC restoration - Is it worth it?
I have a '69 f250 CS Ranger and want to get the factory AC going.
Before i have it gone through, i was just wondering how cold these original systems were capable of getting?
All of the components are in place and the compressor engages when it is turned on, so hopefully it wont cost me my left lung to get it going. Anyone have experience getting their systems going?
If the hoses are not connected, or in poor condition, the A/C is prolly no good...and some specific parts can be difficult to find, some are impossible to find.
Once outside air (the more humid, the worse the problem) gets into the compressor, condenser, dryer tank, expansion valve, the entire system has to be evacuated within weeks.
Otherwise, rust sets in rendering these parts no good.
My (formerly purchased new) 1968 F250 Ranger & 1971 F100 XLT: When the A/C was turned on, the cab got very cold in a matter of minutes.
There were two different types of A/C, Factory installed integral air and dealer installed air.
If the heater and A/C controls are in the same control panel: Factory Installed Integral A/C. If the A/C controls are separate from the heater: Dealer installed A/C.
i acquired mine off ebay and put new hoses on it, but the compressor was shot and gunked everything up. so i flushed it out, got the last expansion valve nos thanks to bill. and during the summer i had measured freezing temps coming from the vents. but ultimately i had problems with that new compressor making horrific noise, (still works though)
and ended up getting a oring leak so now the a/c is a sitting duck. probly someday going to switch out for a new vintage air or classic air setup whatever they are called. i may be looking to sell all the parts soon to hopefully soften the blow of the cost of the new setup.
The noise you hear is prolly coming from the A/C clutch's replaceable bearing, not from the compressor itself.
C9AZ-2990-A (replaced B9ME-2990-A) .. A/C Clutch Bearing (Motorcraft YP-20).
Fits: 1969/79 F100/350, Econoline & 1978/79 Bronco w/Factory Installed Integral A/C / Myriad 1959/79 Passenger Cars w/dealer installed or factory A/C.
The York compressor is the same as: 1968/79 F100/350 & 1978/79 Bronco. Same as myriad 1963/79 Passenger Cars: C3AZ-19703-F.
And that compressor or direct compatable compressor was used in most of the Ford line from 1958 as I remember. And it was used by several of the aftermarket add on air kits of that era. Some had different mounting to the dill valves but they could usually be made to work. You may find that compressor under the hood of anything that of that era. Amazing what scarcity and inflation has done to the price of that compressor. I can remember buying them rebuilt for $50.00 where the going price seems to be around $250.00 now.
I can remember buying NOS compressors from a local salvage yard for 20 BUCKS each.
The yard dismantled 1000's of 1962/64 Galaxie Select-Aire kits (all were hang-on back then) they acquired directly from a FoMoCo parts depot here in LA LA Land.
There may still be some there today. I was there recently scrounging for NOS goodies, but haven't looked for compressors there since Nixon was prez.
I had a working factory unit in my truck and took it out for that reason.
Also have a friend who has a 72 he bought new - with factory a/c - he took his out for the same reason and replaced it with an aftermarket unit.
coolfeet
17
05-05-2016 11:56 AM
Greywolf
Conventional (Bumper Pull) Towing; Travel Trailers & Pop-ups
06-22-2008 08:01 AM
1968, 1969, 2990, ac, add, air, b9me2990a, bronco, c9az, conditioning, customatic, dealer, exspantion, f250, ford, pictures, selectaire, valve, yp20
