Timing gear orientation
Old Apr 2, 2011 | 07:07 PM
kevin316's Avatar
kevin316
I had to pull the timing gears off to fix a mistake my son made when rebuilding his 460 in school. When I reinstalled it I made sure #1 was tdc. The mark on the crank gear was at 12 o'clock and I set the mark on the cam gear to 6 o'clock. (I have no information for the cam).
I got everything buttoned up but I can't get it to fire. I checked the timing with a light and it is firing on TDC. I pulled #1 plug and I have spark but, when I put my finger over the plug hole I get spark then my thumb is pushed off by compression.
My question would be, shouldn't I be getting spark just as I am getting compression? Should my timing marks have been at 12 o'clock on both gears?
I would guess yes but it is quite a bit of work to change it so I want to be sure before I go and change it.
Edit:
Sorry wrong thread. Should be in the Big Block thread. I have posted it there as well so if a mod could delete this please
Old Apr 2, 2011 | 09:08 PM
Conanski's Avatar
Conanski
Timing marks should be facing one another so it sounds like you got that part right, but the motor will need some timing advance to start and run normally so leave the distributor loose enough to turn and crank it around (counter clockwirse) until the engine attempts to start.. that's when you know you are getting close. Once you get it to run then worry about setting the timing correctly.
Old Apr 2, 2011 | 10:52 PM
kevin316's Avatar
kevin316
I tried advancing the timing to about 10 degrees but it just cranks or backfires (or pushes fuel out the carb).
If I had the distribute to far counterclockwise when I lined the rotor up with #1 could that cause this? Maybe I'm one tooth out on the distributor? To be firing TDC I am just about as far as I can go clockwise.
deputydog03
Modular V8 (4.6L, 5.4L)
32
Apr 9, 2016 12:06 AM
deputydog03
1997 - 2003 F150
Dec 11, 2013 01:45 PM
01ArizonaGator
Apr 21, 2013 12:26 AM
kevin316
Apr 10, 2011 09:19 PM
kevin316
Apr 10, 2011 09:15 PM
