Torque Converter Questions
Old Mar 31, 2011 | 05:32 PM
Confederate Diesel's Avatar
Confederate Diesel
Is a 460's engine balance affected by the torque converter? Situation: I installed an '88 460/C-6 into my '66 F-100, using all Ford parts. When the transmission failed, started slipping, I bought a rebuilt unit and torque converter. Now I have a serious vibration from 1600 RPM or so, on up to 3000 RPMs (and higher). As this occurs in neutral as well as on the road, it isn't a driveshaft or driveline issue. Could I have been given the wrong torque converter? Any suggestions?
Old Apr 1, 2011 | 11:14 AM
mcdonaldm's Avatar
mcdonaldm
no, the torque converter is neutral balanced.
but there is two different crank pilot bore sizes for the 429/460. i am not sure what is the cutoff years or application difference to determine which one you have.
sounds like the converter isn't seated correctly or something is not lined up properly.
did you change anything else when you redid the tranny?
rgds
Mike
Old Apr 1, 2011 | 10:12 PM
OldRacerGuy's Avatar
OldRacerGuy
Is it possible to bolt the flexplate on in the wrong spot, out of balance?
Old Apr 2, 2011 | 10:29 AM
monsterbaby's Avatar
monsterbaby
Not if it's the right flex plate, the holes aren't drilled concentrically so it will only bolt on one way.
Old Apr 3, 2011 | 09:00 AM
OldRacerGuy
Oh. Well then <in my best Roseane Roseanadanna voice> Never Mind...
(that only makes sense to the 40+ crowd..)
So what could be causing the vibes?
Old Apr 3, 2011 | 08:06 PM
monsterbaby
A TC with the wrong pilot size as mike mentioned would do it.
Willz74
Nov 20, 2015 09:29 PM
1972RedNeck
Feb 6, 2014 04:57 PM
cory5517
13
Aug 13, 2013 03:23 PM
jgavac
Aug 20, 2011 02:36 AM
z1121jack
Aerostar
Jun 27, 2008 01:01 AM
