Torque converter?
Old Aug 11, 2013 | 11:47 AM
cory5517's Avatar
cory5517
Torque converter?
I have signs and symptoms for a torque converter and a throttle positioning sensor. What are some ways of testing to narrow which part is going out?
Old Aug 11, 2013 | 11:54 AM
mueckster's Avatar
mueckster
Tell us more about these symptoms. Are you getting any codes?
Old Aug 11, 2013 | 12:04 PM
cory5517's Avatar
cory5517
01 f250 cc sb 4x4 7.3. At around 40mph at half throttle I get a shuttering in the gas pedal. Did some Internet shearching and i came to this conclusion.
Old Aug 11, 2013 | 05:29 PM
cory5517's Avatar
cory5517
No codes or check engine light at this time
Old Aug 11, 2013 | 06:17 PM
diehardstroker's Avatar
diehardstroker
im having convertor problems but i dont feel a shutter, my convertor just wont engage sometimes and if im over 2500 rpms it slips constantly but ive never felt a shutter in the pedal
Old Aug 11, 2013 | 06:55 PM
cory5517's Avatar
cory5517
I was told to accelerate until I feel the shutter, which is at 40 mph, and set cruise control for 37 mph and accelerate using cruise control and if it doesn't shutter than its not the throttle positioning sensor. Well I tried it and it still shuttered but I'm not experiencing any slipping so I'm still convinced it is the throttle positioning sensor
Old Aug 11, 2013 | 07:00 PM
diehardstroker
gotcha. im not 100% but i figured i would throw out my symptoms of bad convertor
Old Aug 11, 2013 | 07:02 PM
cory5517's Avatar
cory5517
I'm gonna just replace it and see what happens. If it fixes it awesome if not at least it's a new part and it should be good for a long time
Old Aug 11, 2013 | 09:15 PM
hydro man 17's Avatar
hydro man 17
How many miles on you truck? Are you aware of the common problem with the '01 transmission and the "diode clutch"? May be your issue if it has not been rebuilt already.
Old Aug 12, 2013 | 06:11 AM
cory5517's Avatar
cory5517
I'm currently sitting at 191,100 miles. This would be the first time I've heard about the clutch diode. What are the signs of a bad clutch diode?
Old Aug 12, 2013 | 11:40 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
The symptom of a failed mechanical diode one way clutch is no 1-2 shift, or the shift will only happen at very high RPM after you lift off the accelerator pedal.
Old Aug 13, 2013 | 02:48 PM
fordboy2's Avatar
fordboy2
I seem to have recently had a shutter start at cruising speed any time you are cruising at a steady speed. If you let off the gas it is smooth as silk but anytime you are cruising at a steady speed it has a kinda shutter to it. Cruise or no cruise
Old Aug 13, 2013 | 03:06 PM
Mark Kovalsky
Look for a problem with an injector.
Old Aug 13, 2013 | 03:23 PM
cory5517's Avatar
cory5517
Sounds like your not firing on all 8
Megathomas
Jan 13, 2019 09:00 AM
Tom D
Jul 29, 2017 05:16 PM
djmichael24951
Mar 3, 2014 07:49 PM
cory5517
Sep 16, 2013 03:56 PM
036.0stroke
May 8, 2013 08:27 AM
