C6 Torque Converter
Old Aug 17, 2011 | 08:18 PM
jgavac's Avatar
jgavac
Angry C6 Torque Converter
I have a '79 C6 that was behind a 460, but the engine blew. I picked up a industrial 460 with a heavy duty forged steel crank. As it turns out, the pilot hole on the new engine is 1 inch in diameter. I called a few transmission shops, and they told me that the only 2 sizes for C6/460 torque converters were 1 3/8 and 1 7/8 inch. Is there any torque converter out there that I can put on a 31 spline c6 with a 1 inch pilot hole?
Thanks
Jameson
Old Aug 17, 2011 | 10:20 PM
stuart1's Avatar
stuart1
Oops, I read wrong information.
Old Aug 18, 2011 | 12:33 AM
jgavac's Avatar
jgavac
Originally Posted by stuart1
If the hole is deep enough make a bushing.
I must be missing something... How would that fix my problem?
Thanks
Jameson
Old Aug 18, 2011 | 12:40 AM
ford390gashog's Avatar
ford390gashog
They never made an "industrial 460" ! So you have some issues its either a 429 or 370 lima engine neither will work with a c-6. They are external balance also.
Old Aug 18, 2011 | 01:32 AM
jgavac's Avatar
jgavac
Ok well its not the latter, becaus the block casting is that of a 460. But not that it matters then, because if neither work with a C6, I'm s*** out of luck.
Old Aug 18, 2011 | 01:43 AM
ford390gashog
Those engines had the pilot bearing in the flywheel and not the crank hence why it is so small.
Old Aug 19, 2011 | 11:04 AM
mark a.'s Avatar
mark a.
Why not jut put the converter in a lathe and turn it down ?
Old Aug 19, 2011 | 06:28 PM
stuart1's Avatar
stuart1
There isn't enough material.
Old Aug 20, 2011 | 02:36 AM
Ken Blythen's Avatar
Ken Blythen
No, you're not.
It's a simple job for a machine shop to modify the converter for you to suit that pilot hole.
FossenRacing
Mar 19, 2015 08:15 PM
ladiabla74
Jan 6, 2007 12:39 PM
FordPickup460
Aug 13, 2006 03:16 PM
Piffery1
Dec 3, 2004 08:55 AM
Ratsmoker
Jun 2, 2002 03:00 PM
