Sponsored by: Real Truck
Auto Shifting issue's
Old Mar 31, 2011 | 01:20 PM
Johnniec521's Avatar
Johnniec521
I own a Automatic 1999 F250 7.3 4x4. Over the past 2 weeks while driving down the road I noticed when I'm cruising along in 4th gear and i hit a bump, it downshifts my trans. Sometimes it kicks right back into 4th, other times it will stay downshifted for a certain amount of time with the RPM's around 2500 or more. I figured it was a lose connector, so i took off the connector on the top and side of the trans a put some contact gel on the connector hoping that would work. Well it still does it and I'm not sure what the issue is. The truck shifts fine from a stopped position and all that, It's just when I'm in 4th and hit a bump it downshifts on me... What could be the problem?
Old Mar 31, 2011 | 01:35 PM
Bigpipes 35's Avatar
Bigpipes 35
Next thing I would check is the vss on the rear axle, it is on the top and has a plug on it , make sure that connection is good.
Old Mar 31, 2011 | 01:42 PM
Johnniec521
Thanks, I'll give that a try
Old Mar 31, 2011 | 02:09 PM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
Welcome to FTE.
You might want to look at the wires coming from the OD off button on the end of the shifter to see if one is chafted and grounding when you hit a bump.
Old Mar 31, 2011 | 03:04 PM
Johnniec521
I unplugged the VSS connector and all seemed fine.. I don't have any more contact gel left so i couldn't put any of that on.. I plugged it back in and took it for a spin and it still downshifted over bigger bumps... I'll try looking at the wires on the OD button but I'm not sure that is it.. It seems to do it when the back axle hits the bump...It's hard to explain but just picture several decent size bumps ( potholes ) in a row.. I can literally watch the RPM needle bounce back and forth over each bump as if it kept going from 4th to 3rd... Any other possibilities let me know!
Old Mar 31, 2011 | 03:17 PM
miller_feed
Do you have any mods on the truck. Chip/tuner???
Old Mar 31, 2011 | 03:22 PM
Johnniec521
I have a TS performance chip, Cold air intake, exhaust, etc.... Could the chip be loose?? and when i hit a bump it moves and causes it to shift? i just thought of that
Old Mar 31, 2011 | 03:45 PM
miller_feed
I would take the chip off to see if that is the case. Worth the time.
Old Mar 31, 2011 | 03:52 PM
Johnniec521
It's a 6 position change on the fly.. There is a "stock" position.. would that be sufficient enough to see if that's the problem or should i go underneath and unplug the whole thing? I would think just putting it in the "stock" position would work
Old Mar 31, 2011 | 04:01 PM
miller_feed
I would take the chip out. Don't forget to have the keys far away while doing this.
Old Mar 31, 2011 | 04:07 PM
Johnniec521
I tried turning the Chip to the stock position and it still did it.. Darn i have no clue what it could be..I'll try taking the chip out if nothing else works.. I can't right now cause of the weather.. I was hoping someone else had this same issue and new what the fix was..
Old Mar 31, 2011 | 04:33 PM
miller_feed
If you turn the OD off, does it stay off?
Old Mar 31, 2011 | 04:57 PM
Johnniec521
Yes, and i drove it with OD off over the same bumps and nothing happened.. Its only when OD is on and in 4th gear
kaboom10
1997 - 2003 F150
Feb 26, 2015 09:26 PM
mpally
2009 - 2014 F150
May 31, 2013 12:26 AM
jade79
Aug 11, 2012 09:33 PM
Johnniec521
Mar 31, 2011 09:31 PM
jimbofug
1983 - 2012 Ranger & B-Series
Nov 30, 2010 05:51 PM
