zinc
Old Mar 31, 2011 | 10:02 AM
drewdole's Avatar
drewdole
zinc
in hemmings motor news ive learned zinc has been taken out of oil. the old gassers need zinc added. do our old diesels need zinc too???
Old Mar 31, 2011 | 10:29 AM
wreckinball's Avatar
wreckinball
From the TDR57 article, it hasnt been removed. Maybe in the next batches or CK-4 version. No CK-4 isnt out yet but probably coming, it will have no additives and just kill engines......friggin hippies.
Old Mar 31, 2011 | 10:41 AM
ADTMan's Avatar
ADTMan
Man this sounds like a way for the fat cats to make more money to me. Now we won't add the additive because it is too expensive and because we have to meet guidelines. So here it is in a "cheap" bottle form. Required with EVERY oil change or buy a new engine! SHEESH!
Old Mar 31, 2011 | 10:42 AM
drewdole's Avatar
drewdole
so walmart diesel oil is ok, i ve been running it anyway, just everything cost so much more now
Old Mar 31, 2011 | 10:44 AM
drewdole's Avatar
drewdole
well obamas idea to save u diesel money is buy a new truck
Old Mar 31, 2011 | 12:39 PM
wtroger's Avatar
wtroger
The Ford diesels are all roller cam engines. So we shouldn't see any problems with the low ZDDP oils the bigger problem we are seeing is wear on our injection systems from ultra low sulfur diesel. Any Flat tappet engines are going to see issues. You will have to add ZDDP to the engines especially when the cams are new as in a rebuild. The tree huggers / do gooders are going to push us all to an early grave via starvation.
Old Mar 31, 2011 | 01:13 PM
1994F2507.3L's Avatar
1994F2507.3L
guys this zinc debate has been floating around awhile in the gasser world.
https://www.ford-trucks.com/forums/9...nc-in-oil.html
that hot rod magazine article is from 2007
Old Mar 31, 2011 | 02:07 PM
drewdole's Avatar
drewdole
i hate tree huggers
Old Mar 31, 2011 | 11:21 PM
catfish101's Avatar
catfish101
i hate tree huggers
Exactly and I like trees.
Old Mar 31, 2011 | 11:34 PM
frodfreak's Avatar
frodfreak
in my 351 i have to run a high zinc oil i use Valvoline vr1 racen oil it high in zinc, it was made for flat tappet motors
Old Apr 1, 2011 | 12:17 AM
wreckinball
any CI-4 15W40 is high in zinc. some of the CJ-4's are low but not too bad. The zinc additives are out there some made by edelbrock and some by others. Your mechanics will tell you lots of things but do what you believe. If you want to run moly additives like i do, do that. zinc additives, do that. But dont listen to the goober mechanics that only know modern vehicles that "dont need such additives" like i get told all the time. My engine is quieter and runs cooler with the moly additive. less wear and tear and a bonded surface capable of hyper intense pressures. yeah i like that.
beartracks
Jan 28, 2017 07:06 PM
1972fordhighboy2
Jun 21, 2016 07:31 PM
three.on.the.tree
Oct 31, 2015 08:57 AM
bamaf150
13
Jul 13, 2011 08:20 PM
64F-100
Oct 12, 2010 09:15 PM
