Do i need zinc
Old Jun 20, 2016 | 07:26 PM
1972fordhighboy2's Avatar
1972fordhighboy2
Do i need zinc
Hi there I own a 1985 f250 with a 460.Non catalyst. I was wondering do I need to put zinc in the oil. Also my dad owns a 1984 f150 with a 4.9 straight six but I don't know if I should put zinc because it has a catylitic converter.
Old Jun 20, 2016 | 08:05 PM
Gary Lewis's Avatar
Gary Lewis
That is an on-going debate, and not just here - around the world. I don't think there is a conclusive answer to that question as people on both sides have statistics that support their position.
So, what do I do? I don't run any zinc in Rusty, which has a flat tappet cam. On the other hand, the engine for Dad's truck will have a roller cam and I won't need to worry about it.
Old Jun 20, 2016 | 08:40 PM
Rusty_S's Avatar
Rusty_S
Zinc and converters, I wouldn't buy into it, my '78 Mercury has the original Ford labeled converters on it and they still are functional. If you research you will find that Zinc levels in oils peaked in the '80s. So Zinc harming cats is just a excuse to get rid of it. Now as far as flat tappet goes, I don't run it in my 351W nor my 302 but I do run VR1 racing oil with higher levels of zinc in my 292 as that is a solid lift cam and I rather take extra precaution there.
Old Jun 20, 2016 | 08:48 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
I own an '87 250 with a 460 non catalyst.
I run diesel oil -mostly because of the higher detergent- but it may have more ZDDP
I don't think there is any real advantage to *adding* something to your oil.
If you want higher than currently permissible levels of zinc and phosphorus look at the Brad Penn products.
They are back at SH or SI levels of antiwear additives.
It's the phosphorus that really kills the Cat.
Old Jun 21, 2016 | 11:59 AM
LARIAT 85's Avatar
LARIAT 85
From what I understand, you need the extra zinc when you run an aftermarket performance high lift, flat tappet cam.
For stock, mild cams, I don't think it is really needed.
Old Jun 21, 2016 | 12:04 PM
Festus Hagen's Avatar
Festus Hagen
Methanoholic
I'm on the other side ... I believe Zinc is critical to all flat tappets.
-Enjoy
fh : )_~
Old Jun 21, 2016 | 06:10 PM
FuzzFace2's Avatar
FuzzFace2
I run diesel oil -mostly because of the higher detergent- but it may have more ZDDP.
You may want to look into using diesel oil a little deeper.
The new diesel oils have less zinc in them now days because diesels now have cats also. You have to check the labels to see if is can be used in new or older diesels.
The other thing is foaming. Diesel engines are a low RPM engine, gas engines are high(er) RPM. With higher RPM you get more foaming, more foaming = no oil to bearings!
I did use diesel oil in my AMC drag motor but after I heard that I use normal gas oil with a bottle of Lucus oil products zinc added.
For the AMC street car the same, normal oil & bottle of zinc.
Now I never gave it a though on my 300. Maybe after it is running and I know I sealed all oil leaks I may add a bottle?
Dave ----
Old Jun 21, 2016 | 06:22 PM
Old Hickory's Avatar
Old Hickory
I use ZPPD with every oil change in both my truck which does have a performance
cam in it and flat tappets and in my classic muscle car which also has a flat tappet cam.
If I ever build another moter for my truck I will go to a roller cam.
Old Jun 21, 2016 | 06:26 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
Dave,
That's why I said "*may* have more zinc"
I don't think they do anymore.
After all, diesels have Cats now.
Some of the Brad Penn oils *DO* have all the ZDDP you need to run solid lifters and radical cams.
I -personally- don't believe in messing with the additive package the refiner puts together in their product.
If I want something else I'll buy a product that reflects that.
Rotella and/or Delo seem fine in my engine and inspection proves that sludge is not a problem.
Soon I'm going to have to pull the engine for a reseal and I will do a leakdown before I yank it.
You know I will take pics of the top and bottom while it's out, and post them.
Old Jun 21, 2016 | 07:31 PM
FuzzFace2's Avatar
FuzzFace2
Dave,
I ment to say the AMC guys use the brad penn oil I don't have big money in any of my AMC motors (yet) to run it.
Dave ----
Bootlegger's Deluxe
Jul 2, 2018 02:52 PM
ktm4012
39
Oct 6, 2017 11:07 AM
Old Yblockman
Jun 27, 2017 01:49 PM
ciamcoop
Feb 10, 2017 07:23 PM
Midnite Cruiser
Aug 4, 2009 12:19 PM
