I am having trouble greasing the driver side upper ball joint. It will not take grease. I have tried taking weight off of that wheel, and rotating the wheel back and forth. Any thoughts?
take the grease fitting off and see if grease goes through it. If not replace it with a new one. If it does then take a bit of wire and try to clean any dried grease out of the hole in the joint, replace the fitting and see if it takes grease.
It's probably the grease fitting, but if not, do as Lazy K says and you might also apply some heat to it to soften the grease that is already in there. I have to do that sometimes on the rear wheel on my shredder to get it to take grease.
That sounds like a good course of action guys. I'll mess with it in the next few days.
