upgrading the bus
Old Mar 28, 2011 | 08:14 PM
joetech's Avatar
joetech
upgrading the bus
I am doing the head studs with ford gaskets orings on the heads with new hardened seats. Egr delete and bulletproof oil cooler 8 new injectors 4'' mbrp exhaust erics tunes h/p screen and connector. Replacing the icp sensor and harness. Anything I maybe forgetting while I am rounding up parts?? Thanks for your help.
Old Mar 28, 2011 | 08:59 PM
smokersteve's Avatar
smokersteve
looks good. how many miles? all 8??? what is your issue?
Take off the intake and clean it out. search it on google.
Update the fuel pressure regulator. Ford 3C3Z-9T517-AG International 1843065c98
Update the STC hpop fitting. international 1879930c91
Old Mar 28, 2011 | 09:25 PM
joetech's Avatar
joetech
It just turned 170 on sunday. I forgot about the spring thanks. It misses really bad cold and sometimes hot with contribution codes on 3 cylinders So I figured if ti is apart do them all. I fix cars 12 hours a day I only want to work on mine ONCE.
Old Mar 29, 2011 | 12:16 AM
smokersteve
Before spend that much money on all 8 injectors. First Try Rev-x oil additive. search it on google. You may have an issue with build up on the oil side of the injector, rev-x will clean it out. Also check your FICM voltage, google search. These 2 can contribute to starting issues. Same with the STC fitting.
Old Mar 29, 2011 | 10:17 AM
m-chan68's Avatar
m-chan68
There is no STC fitting to update on an '04 6.0L if that is in fact the model year of the vehicle in question.
Old Apr 6, 2011 | 08:30 PM
joetech's Avatar
joetech
It is an 04 the early one with the ICP in the rear of the engine and a round egr cooler. I got the bulletproof oil cooler in yesterday. What a nicely made piece I hope it works as good as it looks. The gauges head studs are in also. I got magnaflow exhaust. Almost ready to tear into it. Just a few more pieces to get rounded up.
Old Apr 6, 2011 | 09:16 PM
bismic's Avatar
bismic
Edit - misread the post .......
npccpartsman has one and seems very happy w/ his!
Old Apr 6, 2011 | 11:43 PM
smokersteve
Is it oem cooler or the remote cooler?
Old Apr 7, 2011 | 02:52 PM
mixerdrvr's Avatar
mixerdrvr
Maybe the upgraded turbo feed and drain tubes!
Old Apr 8, 2011 | 12:05 AM
Young Gun's Avatar
Young Gun
It sounds like the remote to me.
Old Apr 12, 2011 | 08:44 PM
joetech's Avatar
joetech
It is the remote cooler condenser mount. Just a few weeks till me start tearing in to it.
Old May 1, 2011 | 08:04 AM
joetech's Avatar
joetech
Heads are off going to machine shop on monday. Bulletproof kit is going in. Exhaust is on. It won't be long till we are back on the road.
Old May 1, 2011 | 11:07 AM
smokersteve
Awesome! sounds good! What exhaust and what did you decide to do?
Old May 4, 2011 | 02:14 PM
joetech's Avatar
joetech
I got a magnaflow turbo back 3.5 down pipe no cat and 4 back from the down pipe. bulletproof condenser mount oil cooler 8 reman ford injectors blue spring kit arp studs ford gaskets new belt and hoses heads are getting completely reconditioned new guides and hardened seats and o-ringed. Also installing an A pillar gauge kit with autometer gauges
Gigemags05
Dec 7, 2014 12:54 AM
chamblizi
Mar 31, 2013 12:10 AM
Firemudder
Jun 20, 2012 10:11 AM
red75bronco
Mar 3, 2004 12:16 PM
4294x4
Sep 12, 2000 07:49 PM
