Fuel Leak Under Filter
Old Mar 27, 2011 | 09:30 AM
ScottInTexas's Avatar
ScottInTexas
Give me coffee - Or beer!
2002 F-350, 7.3 ltr.
I have two leaks. One is fuel, the other is oil. The fuel leak appears to come from a point on the back and bottom of the filter housing. It is very difficult to see for certain because the truck has to be running and I have to lean over everything to see. I don't even know what the part is called and the Chiltons manual has nothing. In this forum I found a few references to fuel leaks, but didn't have enough knowledge to figure out what they were refering to.
There are no hoses or anything connected to the point the leak appears to be coming from. It looks like it might be a place for some optional equipment this truck doesn't have. Looking down behind the filter it is on the left side on the bottom of the filter housing.
I'll save the oil leak for another post. It keeps searching cleaner.
Old Mar 27, 2011 | 09:33 AM
megawatt00's Avatar
megawatt00
It sounds like you fuel bowl drain orings are leaking. You can get them from Guzzle
Old Mar 27, 2011 | 09:50 AM
ScottInTexas
Thanks for the quick response!
Then should there be some kind of tube in that spot to direct the fuel onto the ground rather than the valley?
Do you know of a guide to doing the job? At this point I don't even know how to get to it.
Old Mar 27, 2011 | 10:34 AM
timmyboy76's Avatar
timmyboy76
Welcome to guzzle's Powerstroke Fuel Bowl Rebuild Web Page
Welcome to guzzle's Ford PSD Maintenance Web Page
Old Mar 27, 2011 | 10:59 AM
Red Monkey's Avatar
Red Monkey
Replacing those little buggers is a PIA!!! Take your time as it will take longer than you think to replace two o-rings and two screws!!!
Schlominator
Feb 26, 2011 08:39 PM
powerstrokedieselfan
Jan 22, 2011 06:04 PM
texas fling
Jun 22, 2010 01:01 AM
needmolift
May 11, 2009 09:23 PM
flcracker9
Dec 7, 2007 01:12 PM
