Undercoating .... Rhino ..... Herculiner???? F1 Rehab
I've used most of the DIY bedliner products and I agree that the Duplicolor aerosol is the best of them. I've done lots with it but currently I have it on the rocker panels of my '01 Dodge Ram and it's held up quite well over two years and was applied over scuffed factory paint. I get it from O'Reillys, used to get it from WalMart but the ones around me switched to a similar PlastiKote brand which in my experience is complete junk.
Herculiner is good and looks incredible for about a week but then fades quickly to a chalky gray and seems to peel easier than some of the others. I use bedliner on lots of things around the place and until I come across something better i'm sticking with the Duplicolor. You can also roll on Duplicolor if you don't want to spray it, it comes in a jug with a special roller also from O'reilly's.
tardster, do you have any idea of how thick you got the Walmart stuff on in one coat? Did you apply multiple coats? Is that product catalyzed or does it have to air dry? Thanks...
EDIT: I did a little research and from what I have found the WalMart bedliner is Dupli-Color Bed Armor, a water-based product reinforced with Kevlar. I have seen it applied on one of the Trucks! episodes and they spoke highly of it. They did apply a couple of coats and used the roller supplied with the kit.
The beauty of the SEM Metalock product is that it is actually 3 primers in one. Used straight from the can in a 4:1 ratio of primer to catlyst, it is a high build 2K DTM primer. Using half the maximum thinning ratio you will have a primer surfacer that works well for filling in scratches, etc in your filler. If mixed at full thinning ratio it now becomes a sealer, spray it on prior to spraying your basecoat and it will hold out bleeding from earlier paints and fillers. No need to sand the sealer coat before applying basecoat/colorcoat as long as you do it within the prescribed time frame.
SEM Metalock is available online for around $100 for the kit, 1 gal primer and 1 qt catalyst. I pay $85 here from my jobber. I don't use the Martin Senour line, not because I find it lacking but just because I have used DuPont, PPG, SEM, and HOK products for so long that I never saw a need to try something new.
ultraranger
General Automotive Discussion
13
05-20-2016 03:43 PM
mr.fordneck
11-24-2011 10:15 AM
