Here we go again
Old Mar 25, 2011 | 09:35 PM
cummins cowboy's Avatar
cummins cowboy
Originally Posted by 6.7Fan
I'd like to hear more about the "chutter" I think I have the same issue as you. "Chutter" is probably a good description. At low RPM's (for me, it is more often as soon as it shift from 5th to 6th gear with very little throttle) the truck kind of shakes just a bit, but I hear a sound that....the only way I can describe it is air escaping from a balloon in very short, rapid bursts. It's much different than the other transmission issues I'm having (hard shifts, occasionally slipping into neutral, hard downshifts, hunting for gears, etc).
Again, I've posted this before, I love this truck. The issues I have a sporadic and minor, just not expected for the money I have in this thing. And, they are getting worse.
Anyway, is your "chutter" similar to what I described above? If so, you are the only other person I've seen with it on here. It's very strange. And to be honest, I haven't had it in to the dealer to be looked at yet. Hate the inconvenience.....
I think I have the same thing, does it occur between 40-45 mph?? its almost when the engine is lugging. if I speed up or slow down it goes away.
Old Mar 25, 2011 | 09:50 PM
6.7Fan's Avatar
6.7Fan
Yes - right around 40-45. For me, it happens everytime on the same roads on the way home. I can keep it from doing it if I lock out 6th gear when going that slow. Just seems like it's shifting early, but I have no idea what that sound is.
Old Mar 25, 2011 | 09:58 PM
cummins cowboy
yep we got the same thing going on then it also has almost an ever every so slight bucking feeling right??
Old Mar 25, 2011 | 10:08 PM
6.7Fan's Avatar
6.7Fan
Exactly. Pretty sure if I kept the throttle at constant pressure when it happens, it would just keep shaking. i've gotten so used to it now I just immediately let my foot off the gas for a second to make it stop....just like the slip to neutral.
I'm enthusiastic for the new transmission TSB that should be coming out....really hoping that fixes all the issues.
I've also got my battery disconnected tonight to reset the transmission learning process to see if things go back to the way they were for the first few thousand miles.
Old Mar 25, 2011 | 10:24 PM
kper05's Avatar
kper05
I lock out 6th quite a bit for speed zones 45 or below (sometimes 50 or below).
The only times I don't is when I forget.
Since I do the above so often, I'm interested to see the results so I'll test this out.
Old Mar 25, 2011 | 11:00 PM
Tom Hoffman's Avatar
Tom Hoffman
That is exactly what i feel. Almost to low of RPM for the load.
40 mph chugging
Well that is 3 of us
I can live with that i think, but it makes you wonder.
The exhaust in the cab has to go!!!
The wind noise has to go!!
I am a very **** person! I like my stuff perfect!
I have a membership to a car wash
I drag race snowmobiles and you can eat off any part on them
I have a deer blind that is 30 ft in the air with a front porch, wall to wall carpet, it is 8x10 with heat, lights,tv. Hell i take my boots off when i go in!
That is how i am
I want it right and for 60k i really want it right!
Old Mar 25, 2011 | 11:14 PM
marine57_4's Avatar
marine57_4
yeah!! that is the sound and the shakes are identical. mine did it while i was in los angeles, ca and carson city, nv. i am back in albuquerque, nm and it has not done it yet. maybe the difference in altitude?? it is around 6k feet above sea level. of course la angeles is just a few hundred feet above sea level. i do not know what carson city is.
Old Mar 25, 2011 | 11:18 PM
6.7Fan's Avatar
6.7Fan
Well, I know that Cummins Cowboy and I are in Herriman, UT. This is approximately 5,000 feet altitude....so altitude could have something to do with it.
Old Mar 25, 2011 | 11:36 PM
marine57_4's Avatar
marine57_4
we are about 1k feet difference, yet it does it for you but not for me in albuquerque. i got to try it again and see if it will do it. either way i am going to take it in because i do not want this happening every time i go to california. besides the chutter can not be good for the engine.
Old Mar 26, 2011 | 07:34 AM
sdetweil's Avatar
sdetweil
40 mph chugging
That is how i am
can't help with the driveability issues, but Epic has solved the wind noise by adding some surgical tubing to the door gasket on the drivers side.
from the tech folder
https://www.ford-trucks.com/forums/9...ml#post9065695
sam
Old Mar 26, 2011 | 11:32 AM
cummins cowboy
I don't have any wind noise in my truck, I do have the chuttering and the pop out of gear problem though. the chuttering I don't think it is a big deal, should it be there NO, is it causing long term issues with the truck maybe but I don't think so.
did a fuel mileage check the other day, for you utah guys, drove up parleys, through kamas over to woodland stopped there and then drove back home to herriman, mostly highway but a little stop and go in there going through towns and at lights coming back home. 18.3 mpg, pretty darn good I say on winter fuel. my 06 dodge would have been lucky to be at 15mpg on the same trip.
Old Mar 26, 2011 | 12:03 PM
grippy6176's Avatar
grippy6176
backup sensor
Originally Posted by rickatic
Tom
My truck does the backup sensor beeping but it is not consistent. Some cold days it does it and on some it does not. Wiping the lens does not always help but sometimes it does. If it is beeping when I back out of my driveway and I take it to the car wash, it will stop...I don't know but I just turn it off. Maybe AE will give us that option as well...
Regards
I had the same problem on my truck but to fix it I took a can of silicone and sprayed the back of the sensors, it keeps the water out. After washing the water freezes in and around the sensor keeping it on. Now that its getting warmer you might wait till next winter.
Old Mar 28, 2011 | 08:29 PM
  #28
Tom Hoffman
Update
Well i called and they are changing the EGR today. They are calling in someone for the fumes in the cab. I asked why it has been a week and they only just started on it. That was when the rental truck was available
Well Wednesday i am pulling a 10,000 pound trailer with there brand new F150 loaner they gave me. It had like 40 or60 miles on it when i got it turned 500 today. Luckly i only have to pull it 10 miles one way.
So they need to fix. Air leak drivers door, rattle in left dash area when stopped idling in gear with foot on brake, recall for BCM, fumes in cab, back up sensors, and CEL they say it is EGR. they have had it sence the 22nd this time.
Old Mar 28, 2011 | 08:57 PM
  #29
rollerstud98's Avatar
rollerstud98
At least nobody is jumping down your throat this time! Horrible that you have diesel problems again.
Old Mar 28, 2011 | 09:37 PM
  #30
Tom Hoffman
Thanks i bet a few feel bad about how they talked to me.
Because i think the 6.4 got a few of them also! Just a little later than me.
This is really a nice truck just a few issues. The biggest issues i seem to have is incompetence at the dealer they really have no clue and will lie to your face.
In the end it is Fords fault they dont train dealers better.
I sure hope this truck gets fixed to my standards, i cant go through the buy back again. It really sucked!
