1958 Shock Question
Old Mar 17, 2003 | 07:54 AM
wilson3821's Avatar
wilson3821
1958 Shock Question
This might sound stupid, but I have to ask even know I think I already know the answer.... Did the '58 F100 come with shocks on the front? It does have springs on the front, however the guy I purchased the truck from stated that the '58's did not have front shocks even though there appears to be mounting brackets for them.... I am going to need to get a book.... Thanks!
Old Mar 17, 2003 | 12:36 PM
Kenny's Avatar
Kenny
1958 Shock Question
Hi,
Not a stupid question at all!
The '58 F-100 did come with both front, and rear shocks.
Note: on page 29 of Paul G. McLaughlin's book "Ford Trucks 1957-'67", shock absorbers are listed as "1958 F-Series options, Factory installed". I don't believe this is correct.
Other books I have show "Front & rear double-acting, telescopic shock absorbers" as standard equipment for the 1958 F-100.
Hope this helps.
Old Mar 17, 2003 | 12:52 PM
wilson3821's Avatar
wilson3821
1958 Shock Question
Thanks! I noticed that Auto Zone list Gabriel shocks Fronts 81270 and rears 82123.... Never have installed shocks so I guess the research starts again.... I am not sure how to install the front shocks since I do not know what they looked liked before. I know that I will need bolts etc...but what type, are there brackets that need to added? any suggestion would be appreciated... Thanks!
Old Mar 17, 2003 | 01:10 PM
Big Hands's Avatar
Big Hands
1958 Shock Question
Wilson,
Generally there are several types of shock mounts. The first type consists of a pin or bolt affixed to the spring or rear end and the frame. The shock will have an eye similar to an eye bolt. Shock goes over the bolt and a flat washer and nut are attached.
Second type would be as used on some cars. The top shock mount is actually the shock piston rod, that is threaded. You place a flat washer against a stop, then a bushing and slide the rod through an opening in the body, then place a bushing, flat washer and nut on the top of the shaft. Tighten until the rubber busings equal the size of the washers.
Third type has a mount similar to the 1st type, ie, eyebolt, but has a bracket through the eye with a flat plate on the end drilled to allow a mounting bolt to pass through. The bracket resembles two wyes back to back.
I'm not sure which type you have but would believe it probably is type 1.
Hope this helps
HAnds
Old Mar 17, 2003 | 08:33 PM
angus's Avatar
angus
1958 Shock Question
I'm pretty sure the shocks mount like #2 (top and bottom): there's a bracket off the frame rail at the top, and a plate sticking out from the axle near the springs. Once you have the shock in your hands it'll be obvious how it mounts.
Old Mar 19, 2003 | 11:26 AM
DS02F250's Avatar
DS02F250
1958 Shock Question
Gabriel's will work, as will MonroeMatics. Either one gives a nice ride (well, nice as it can given a straight axle suspension)
Daryl
Old Mar 19, 2003 | 07:31 PM
Earl's Avatar
Earl
1958 Shock Question
Daryl
Now Daryl, don't be dissing the stock front end. "nice as it can given a straight axle suspension" is amazingly nice.
I sit in my truck (well, on the cross member) and imagine I'm going down the road with my fully rebuilt front stock suspension. Ahhhhh, feel the wind in my hair. OH NO! A bump! Nooooo problem. The perfectly designed straight axle navigates the obstruction with ease.
I got Monroe's for my 1956 by the way.
Obligatory posting key words: "Ford" "1956"
Old Mar 19, 2003 | 08:21 PM
Kecky's Avatar
Kecky
1958 Shock Question
George, did you grind the ends of your leaf springs to reduce the chance of the leaf digging into the one above it and helping with movement?? I've been told to do this but have not talked to anyone who can say that it actually works. I looked at your site (it's great by the way) but you didn't mention anything like this.
My straight axle is out getting new king pins and I've got a Toyota box to hook up to it. Oh ya 56 F100.
Kevin
Old Mar 20, 2003 | 06:00 AM
Earl's Avatar
Earl
1958 Shock Question
I did make sure the ends weren't riding in grooves worn in the next leaf. I also made sure none of the spring ends had sharp corners on their upper sides at the ends. In my case, none did so I didn't have to grind them. The new leaves I had made were already beveled slightly by the spring shop. Apparently they knew this was important to keep the lower springs from digging into the next higher spring leaf.
JimDev57
Apr 1, 2013 06:43 AM
barnfind 51
Oct 9, 2012 11:14 PM
BigBlack71
31
Nov 23, 2010 10:43 AM
crazyrwe
Jun 27, 2008 03:30 PM
alpo23
1978 - 1996 Big Bronco
Apr 3, 2003 11:13 AM
