Can I drive without shocks?
Old Nov 21, 2010 | 04:40 AM
BigBlack71's Avatar
BigBlack71
I know this probably a pretty basic question, but I just got some add a leafs installed and summit sent me the wrong front shocks. Over the next few days I cleaned and did the front wheel wells with POR15. I took the shocks off. I have to bring the truck down the road for an alignment on Wednesday. Can I take it down the road without front shocks?
Old Nov 21, 2010 | 05:04 AM
jowilker's Avatar
jowilker
You should be able to. You might want to call the shop to see what they think.
John
Old Nov 21, 2010 | 06:02 AM
Diesel Man 03's Avatar
Diesel Man 03
If you don't have to drive too far and are able to keep your speed down you should not have a problem.
Old Nov 21, 2010 | 06:08 AM
Skip1970's Avatar
Skip1970
heck i been driving with 1 shock on the front for years! instead of using the factory mount i just welded a mount in the middle so i can save some $$ by only using one .
Old Nov 21, 2010 | 06:39 AM
71 Sport Custom's Avatar
71 Sport Custom
I would say they are there for a reason. I'd say don't do it. Depending on your new shocks this could affect the alignement if you put them on afterward.
Old Nov 21, 2010 | 07:11 AM
BigBlack71's Avatar
BigBlack71
Okay maybe i'll just push the date of my alignment to thursday. the shocks should be here Wednesday. I don't want to mess anything up. Even if it is only a miles down the road. I wasn't sure if it would affect my alignment?
Old Nov 21, 2010 | 08:48 AM
project_livewire's Avatar
project_livewire
I don't think shocks will affect the alignment. I would think it would have the same caster/camber no matter what kind of shocks or lack of shocks you have
Old Nov 21, 2010 | 09:43 AM
Victor L's Avatar
Victor L
Being that your truck is a 3/4 ton, the suspension is probably stiff enough
that the shocks dont do that much anyway.
I got an old 1940's 3/4 ton, there's not much left of the original shocks,
and it rides fine.
Old Nov 21, 2010 | 03:17 PM
Skip1970's Avatar
Skip1970
shocks are for them fancy rich folks that need a car like ride in their trucks, when they made real trucks u couldnt tellt he difference without them.
Old Nov 21, 2010 | 03:28 PM
douglpr42's Avatar
douglpr42
to make habit of driving without shocks would be insane from a safety view point .a short trip driven carefully should be ok but should check with front end shop as to having any efect.
project_livewire
^^Agreed!!
Old Nov 21, 2010 | 04:56 PM
jowilker's Avatar
jowilker
It is not gonna hurt anything to drive it to a shop. I suggested prior to contact the shop just in case it might effect their equipment setup.
John
Old Nov 21, 2010 | 05:32 PM
CougarJohn's Avatar
CougarJohn
Sure you can drive without shocks. And you can do your own brain surgery too.
The shocks are there for a reason. They take the road hit and transfer it up to the frame. Without them the suspension rubber has to absorb it all.
You won't do much harm going around town for a few days without shocks but get them in as soon as you can.
Old Nov 21, 2010 | 05:43 PM
71 Sport Custom
A good front end mechanic and shop take their job very seriously as what they do has a huge impact on the safety of ALL drivers on the road. If their job is done incorrectly they will have a liability on their hands. Someone driving an unsafe incomplete vehicle is certainly a choice of their own but the shop can't make this choice for others. They will most likely pull the truck right back outside and charge you for the alignment as they could have been working on someone elses vehicle. I would not want to be in a wreck with injuries and property damage to be found with any parts having to do with safety missing? It could very likely change who is found at fault and liable.
Old Nov 21, 2010 | 06:02 PM
Skip1970's Avatar
Skip1970
even if you HAVE shocks allot of the vehicles runnning around they dont even work. old wore out shocks do nothing for saftey
