Water not good
Old Mar 23, 2011 | 09:49 AM
j dubb's Avatar
j dubb
Water not good
Can anyone help? My visor leaked. I got some water in the cab. I have a 2001 F-350 diesel. Something under the dash beeps. It beeps 5 times and theres 5 cycles. Also my relay #1 buzzes. Also my speedometer bounces all over the place along with a flashing overdrive buttom. Also the sound from my radio stops when I put the truck in drive. But I can see that the radio is still on. Or should I call ghost busters???
Old Mar 23, 2011 | 10:22 AM
timmyboy76's Avatar
timmyboy76
been there, done that
Just got done, chasing same situation. My GEM module, was getting wet, behind the fuse block panel. Sounds like you need to re-seal the front windshield/replace with new.
Is your airbag light on / works. If its out, doesnt light up, then thats the warning sound your hearing (5 sets of 5 beeps). You need to replace it with a 12v light. After numerous led lights..etc, finally found a 12v led, installed it, and cured the beeping. But, your GEM is acting up, from getting wet, thats why your gauges, blower motor is on,..etc, is going looney, with key not in.
Old Mar 23, 2011 | 11:05 AM
orng1's Avatar
orng1
Common issue when the window leaks. Everything gets wet and starts acting funny. Like Timmyboy76 said, reseal the glass and check the GEM and light.
Old Mar 23, 2011 | 11:06 AM
BillyBob69's Avatar
BillyBob69
What he said^^^^
Pull your fuse panel and gem and dry everything out. If you are lucky nothing was ruined and drying it all out will take care of the problem. Otherwise.... you could be looking at replacing the GEM module. And while you are at it, seal off anything in the visor that could cause this leak.
Old Mar 23, 2011 | 01:11 PM
bulla's Avatar
bulla
You know lots of people say windshield leaking but couldn't cab lights cause the same issue if one of them was leaking?
Old Mar 23, 2011 | 01:54 PM
Kwikkordead's Avatar
Kwikkordead
I think your headliner would get water stains if that was the case.
Old Mar 23, 2011 | 03:21 PM
bulla's Avatar
bulla
Only reason I suggested it was cause one day after alot of rain, I backed off a curb to leave work and got a bath from the cubbyhole below the overhead display. Just a suggestion!
Old Mar 23, 2011 | 03:23 PM
BillyBob69's Avatar
BillyBob69
He mentioned his visor leaked....I am assuming that means the windshield visior attached to the roof.
Old Mar 23, 2011 | 05:02 PM
bulla's Avatar
bulla
Visor, ok I was thinking sun visor in cab not one on top of cab. I did have a cab light leak so for future reference when diognosing a water in gem problem check those also before having your windshield ripped out for nothing!
Old Mar 23, 2011 | 05:36 PM
j dubb's Avatar
j dubb
Awsome !!!! I'm gonna give it a try
Old Mar 23, 2011 | 05:51 PM
ltl_jrw's Avatar
ltl_jrw
My cab lights were leaking and my GEM got wet. Thought it was the windsheild but when I had the windsheild replace they said that it was not leaking so the only place for it to get water in was cab lights. Resealed the cab lights and no problem since and the head liner never got wet.
Old Mar 23, 2011 | 11:01 PM
j dubb's Avatar
j dubb
Is there a store on-line that sells the GEM modulars?
Old Mar 23, 2011 | 11:07 PM
JT250's Avatar
JT250
Sure glad I don't have cab lights!!!
Old Mar 24, 2011 | 06:03 AM
ltl_jrw's Avatar
ltl_jrw
I bought a new GEM off E-Bay, had to send them my vin so it could be programed to my truck.
EconolineFan
21
Nov 27, 2013 05:39 PM
johnmsch
2009 - 2014 F150
Mar 4, 2012 05:28 PM
Fordenthusiasts
Apr 23, 2011 10:19 AM
ddraper
1983 - 2012 Ranger & B-Series
Oct 1, 2010 02:50 PM
Flip4ford
Kansas Chapter
13
Dec 31, 2008 12:09 PM
