Weird beeping before starting
Old Apr 22, 2011 | 06:41 PM
Fordenthusiasts's Avatar
Fordenthusiasts
Today when I went to start my pickup I turned the key and nothing happened. The dash lights (check engine, ABS etc.) were very dim also. So I left the key in the run position for a while, the dash lights stayed dim the radio didn't come on, then after about 10 seconds there were 3-5 weird beeps. Didn't sound like door open beeps, or lights still on beeps, but some computer type beeping. After the weird beeps everything came to life and then I tried starting the pickup and it started and ran just fine.
So the question is what were the beeps and what did they mean?
1995 F-150, 4x4, 302, MAF, OBD 1
Old Apr 22, 2011 | 07:22 PM
tjc transport's Avatar
tjc transport
i ain't rite
check your battery cable ends and connections.
Old Apr 22, 2011 | 08:49 PM
Fordenthusiasts
Thanks, I'll check them, but why would things go dim and then come back to life after a little bit. Wouldn't they just stay dim?
Old Apr 23, 2011 | 06:18 AM
tjc transport
i ain't rite
sometimes a bad connection will reestablish itself. i see it a lot with grounds. once enough current passes through the bad connection, it will start working again.
Old Apr 23, 2011 | 09:28 AM
mojo79's Avatar
mojo79
This may not be your issue, but I did encounter a wierd beep yesterday that I have never heard before... so thought I would share the info in this thread. I removed one of my dash panel bulbs (#194 bulb) and then turned ignition on. There evidently is a beeping sound thought alerts you that a bulb is out or not working. it's a different sound beep. I put the bulb back in and no more beeps.
Old Apr 23, 2011 | 09:45 AM
Roger T. Pipe's Avatar
Roger T. Pipe
^^^^^ Yup, what Mojo said. This happens when you try to pull a bulb out on a certain function, say "Check Engine" for example. When the bulb is missing or burned out, you will get a bong bong bong sound in place of it. Its a safety feature, I believe.
Roger
Old Apr 23, 2011 | 10:19 AM
Fordenthusiasts
Thanks guys, that makes sense because the bulbs were very dimly lit and for all I know one may not have been lit so it may have triggered that sound, and now that you say that Roger, it did sound more like a bong bong bong instead of a beep.
So more than likely the no start problem and dimly lit lights was a ground problem?
JessieDM
19
Dec 30, 2024 04:44 PM
04badford
1997 - 2003 F150
Dec 12, 2015 09:29 PM
JaySVX
Oct 20, 2014 10:18 AM
chadwick623
Jul 22, 2011 02:28 PM
Hondaonda
Apr 5, 2011 11:31 PM
