Engine hoist
Old Mar 22, 2011 | 10:44 PM
hasteranger's Avatar
hasteranger
I used a 1 ton hoist and the ram will handle the weight with no problem. The one thing is that a 1 ton hoist has a smaller foot print than the heavier hoist, so once you start trying to slide the hoist around with a motor on it, even if you drop the motor down, there is a greater chance of you tipping the hoist (which has happened to me twice with my 1 ton, once with a 351 and once with a 460 hanging off it, both times with tranny/tcase so prolly pushing 1000 lbs).
At any rate, I've pulled both 2wd engine/trannies and 4wd engine/trannies without lifting the truck at all. as others have said, you will get enough angle when you start jacking up the motor. As far as I can tell, btw, its not possible to pull the tcase with the transmission/motor without undoing the front cab mounts... not sure if you have a 4wd or 2wd.
I'd personally recommend pulling the front clip. Its incredibly easy and makes pulling the motor much much easier, not to mention getting the new motor back in and everything hooked back up. I'm getting ready to swap the motor in another truck and I'm pulling the front clip.
And I'd also recommend buying a slightly larger hoist for greater stability, if you can afford it.
Old Mar 22, 2011 | 11:06 PM
lonnie1952's Avatar
lonnie1952
Originally Posted by 704 dentside man
Fully dressed 460 will weigh in at 625lbs, C6 will roughly be 250lbs. So 875 lbs is well below the one ton limit.
the 460 is MUCH heavier
620 would be a FE big block
http://www.mustangsandmore.com/ubb/E...imensions.html
http://raceabilene.com/kelly/hotrod/engine.html
Old Mar 23, 2011 | 07:17 AM
BiltFordTuff's Avatar
BiltFordTuff
My dad has a 2 ton foldable HF hoist (just for the dependability) and I would only buy a four legged stand.
Old Mar 23, 2011 | 06:31 PM
devino246's Avatar
devino246
I agree. I had a mopar slant-6 tip over when it was on a 3 leg stand. Didnt do any damage but it scared the crap out of me.
PapaBearYuma
24
Nov 12, 2016 10:54 AM
n8ishooiam
Garage & Workshop
May 29, 2011 06:59 AM
59INA40
Garage & Workshop
Oct 9, 2009 01:40 PM
Grizzle33
Sep 26, 2009 06:36 PM
AZAV8
Garage & Workshop
Feb 25, 2006 05:10 PM
