recommend for/against an engine hoist and engine stand?
I have an F250 with a 390 which is under 700 lbs. Just curious about pickers and stands I should shoot for or stay away from. At Autozone there's a brand new Duralast engine hoist for $300 and stand for $70. I'm not familiar with brands. Is there a better brand I should go for or do you pay for the name brand?
HF has the nice hd stand on sale right now. I have rebuilt a few 390's on the 700 lb stands they are fine just don't try to rotate the engine or the whole thing will flip!! DONE IT!!!!! Harbor Freight Tools
I recommend against a three-point stand (tricycle) as they are inherently unstable. Get one with four wheels with a wide stance as illustrated by Jeg's PN 555-80041. However, it doesn't have a geared rotating mechanism like PN 555-80059. I'd probably get the latter and modify the front "axle" to be at least as wide as the rear.
When rotating without the gear box, go slow or else the block's momentum will flip it over and land on soft body parts... keep your fingers clear of pinch points too.
Received 3,101 Likes
on
definitely watch the cheap engine stands. you wand one with a mounting plate at least 3/8 inch thick, 1/2 inch preferred.
the thinner plates like the 1/4 and 3/8 mount will bend with the weight of a large V-8 engine.
i had borrowed a cheaper stand once and the plate bent so bad that a 400 ford had the lower pulley sitting on the floor after sitting on the stand overnight.
as for the hoist, go with a full sized one. the folding ones are not that good.
i have an old 12,000 lb unit with a 8,000 lb air over hydraulic ram on it i picked up at harbor freight.
PapaBearYuma
24
11-12-2016 10:54 AM
Grizzle33
09-26-2009 06:36 PM
