Uh Oh.....
Old Mar 17, 2011 | 09:53 AM
caiati's Avatar
caiati
Uh Oh.....
2006 F350 6.0 PSD totally stock. I pulled into the gas station this morning and it started to run rough. Never happened before. There was no check engine light and nothing coming out of the exhaust. I shut it down and fueled up. Started it back up and it was still running rough as if it were going to stall. I pulled out from the gas station and it kept doing it. I gave it some WOT for a little bit and it stopped. Drove another 60 miles and all seems fine. I have 125,000 miles. During all of this I couldn't see any white smoke coming from the exhaust and the temp stayed normal. Is my EGR cooler going out? Should I be worried? Any advice is helpful thanks.
Old Mar 17, 2011 | 10:38 AM
cartmanea's Avatar
cartmanea
Did you let it get really low on fuel?
Old Mar 17, 2011 | 11:02 AM
caiati's Avatar
caiati
The low fuel light had just turned on, but that has never happened before. Do you think that's what could have caused it? Maybe some dirt at the bottom of the fuel tank?
Old Mar 17, 2011 | 11:26 AM
cartmanea's Avatar
cartmanea
It kinda sounds like you sucked some air into your fuel system. If it's running fine now, I wouldn't worry about it too much. Best to not let it get below 1/4 tank, air is VERY hard on these injectors.
Old Mar 17, 2011 | 12:09 PM
caiati's Avatar
caiati
Ok good to know, thank you
Old Mar 17, 2011 | 12:10 PM
caiati's Avatar
caiati
How do I prevent sucking air? Stay above 1/4 tank?
Old Mar 17, 2011 | 12:16 PM
cartmanea's Avatar
cartmanea
Yes, that's what I try to do. I have seen my fuel light a few times though with no issues. Also, with the 6.0L it's very important to change both fuel filters regularly (every 10-15k) and drain your fuel/water separator on a regular basis. If you can keep your fuel system healthy you'll eliminate a lot of common problems with the 6.0L.
Old Mar 17, 2011 | 12:26 PM
hubler13f's Avatar
hubler13f
Yup stay above 1/4 tank when possible. There is a little bright orange rubber valve or bypass about 2" up on the boot at the bottom of the fuel suction tube. Sometimes it will fall out or allow air to bypass which can lead to your truck shutting down or running rough around 1/4 tank due to air in the lines or starving for fuel.
Heres some pics:
Old Mar 17, 2011 | 12:37 PM
caiati's Avatar
caiati
Thanks for the info and pics!! Where exactly is the fuel water seperator located so I can give it some attention?
Old Mar 17, 2011 | 12:39 PM
cartmanea's Avatar
cartmanea
On the left frame rail next to the transfer case. That is where the primary fuel filter is too. If you haven't changed filters at all, do it ASAP and ONLY use Motorcraft or Racor filters (Racor makes them for Motorcraft).
Old Mar 17, 2011 | 03:26 PM
amdriven2liv's Avatar
amdriven2liv
I'm hitting easy street
Look in this picture. See the fuel heater harness is covering the brass screw. Careful they have a tendency to strip.
Picture is from this manual.
Powerstroke 6.0L Technical Intro Manual
robkisgod
1983 - 2012 Ranger & B-Series
13
Oct 11, 2014 08:36 AM
blueray
20
Mar 7, 2013 12:53 PM
big dirty
Feb 26, 2013 08:44 PM
Doucheatron
Feb 1, 2013 09:08 AM
blwilli
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
Dec 16, 2004 12:38 AM
