Scangauge 2 EOT programming
Old Mar 16, 2011 | 10:02 PM
starrs's Avatar
starrs
I recently installed a scangauge 2 in my 2003 X. I went to scangauge website and programmed EOT. Problem is the data shows about 6 degrees warmer on scangauge than what my modis reads. ECT is identical. Has anyone tried different codes for EOT on a 2003? I found a couple different ones floating around the web but wanted some input here. I wonder if some trucks are a little closer in temp spread than what scangauage data shows? Current code im using is:
TXD 07E0221310
RXF 046245130610
RXD 3010
MTH 00090005F05F
Old Mar 17, 2011 | 12:45 AM
amdriven2liv's Avatar
amdriven2liv
I'm hitting easy street
I have an 04 and I used the one in the pdf for xgauges. Works fine.
There is another like you said;
Engine Oil Temp.
07E0221310
046245130610
3010
00090005F05F (00090005FFD8 was posted on another thread, I used the one out of the Xgauge pdf)
EOT
Other than that. Good check is first thing in morning. Both should read nearly equal.
Old Mar 17, 2011 | 08:34 AM
starrs's Avatar
starrs
First thing in the morning scangauge reads 3 degrees higher eot whereas modis scanner reads identical. Only reason why I compared is because scangauge was giving me over 15 degree spread under heavy load on highway, modis scanner never saw more than 8.
satwood
Nov 29, 2014 07:58 AM
Number21
Apr 27, 2014 12:58 PM
Bruin008
Dec 26, 2012 09:04 AM
rattleNsmoke
Jul 31, 2011 10:20 AM
hndacr
Jun 2, 2010 08:31 AM
