My progress..
Old Mar 16, 2011 | 01:13 PM
salf100's Avatar
salf100
My progress..
Just thought Id post some pics of my latest progress. I finished my rear axle flip and it came out great. While I was there, I figured Id scrape off the old undercoating and prime and paint the frame. Need to buy new spring bushings next, think Im going with poly ones from energy suspension. Any tricks to getting the old ones out? Its been 3 years in the making and still have a lot to go
WHAT DO YOU THINK OF THE TATTOO !! No muscles
Old Mar 16, 2011 | 02:08 PM
Ziegelsteinfaust's Avatar
Ziegelsteinfaust
Looking good.
How do you plan to handle the tat as you modify the truck?
Old Mar 16, 2011 | 09:05 PM
salf100's Avatar
salf100
Tat stays the same! I know it doesn't look like much, but heres a list of some of the new goodies:
Rebuilt carb
new water pump
new radiator
new oil pump
Sanderson headers with smitty's
new clutch
new drum/disc power brakes
new fuel and break lines
new rear axle seals w/powder coated back plates
cleaned and resealed gas tank
recovered bench seat
scraped off all under coating under bed and re-coated
removed undercoating on back half of frame and repainted
new windshield and back window with rubber
repaired rotted battery tray etc, etc.
Not bad for only a day or two of work a month!
Old Mar 16, 2011 | 11:12 PM
Ziegelsteinfaust
I love it.
Basic and simple.
I am planning to red oxide prime my eventually, and just lower the hell out of it. The Pepto color just doesn't do much for me.
Old Mar 17, 2011 | 10:56 AM
salf100's Avatar
salf100
Yup - I plan on using mono leafs up front, but right now im dealing with rebuilding the manual steering box. Not sure if I ill do it my self or send it out. Found a good shop in San Jose, CA to do the rebuild. I looked at upgrading to a different manual box......but dead ends there.
Old Mar 17, 2011 | 11:09 AM
Ziegelsteinfaust
Mor-Drop is up your way, and it solves the oil pan to beam problem.
Old Mar 19, 2011 | 12:09 AM
salf100's Avatar
salf100
Is there a clearance issue using mono leafs?? I was not aware.
Old Mar 19, 2011 | 01:15 PM
ki0cn's Avatar
ki0cn
I have reverse eye mono leaf springs on the front of my 61 uni 223 six. the only way the beam could come in contact with the oil pan is if the rubber bumpstops were missing. granted there isnt much travel only about 1 1/2. I'm happy with mine but a dropped axel might be a better choice if you really want to get low and keep the I beam.
Randy
Old Mar 19, 2011 | 05:52 PM
salf100's Avatar
salf100
ok good to know. im not quite there yet, im dealing with my steering box now. not sure if I should rebuild it or have a shop do it. Ive never attempted anything like that before.
sons73
17
Nov 8, 2011 12:07 AM
Country Sweetie
35
Oct 26, 2011 06:59 PM
salf100
Sep 9, 2011 12:17 PM
Country Sweetie
21
Jul 9, 2011 04:41 PM
98SVTCobra
32
Apr 6, 2008 02:28 PM
