Noticed check engine light on,,4 codes,,
Old Mar 15, 2011 | 11:30 AM
m350's Avatar
m350
Well today pulling my trailer with my 06' F-350, 6.0,,Pulling a hill, prob about 3k rpm,,noticed the check engine light on,,,truck was running fine,,,got Home,,let her idle,,,checked to see what (or if any) codes,,with my Edge Insight,,,yep 4 of them,,,
#1 PO261 Cylinder #1 Injection circut low
#2 PO273 Cylinder #5 Injection circut low
#3 Cl503 unkown
#4 Pl555 unkown
truck ran fine,,,got 58k plus on her,,,first time ever seeing a code on this truck,,she has Been Great,, anybody have ideas on what these mean ?
Thanks,,,,,,Mark
Old Mar 15, 2011 | 11:50 AM
amdriven2liv's Avatar
amdriven2liv
I'm hitting easy street
Here is a DTC list
http://www.dieseltalk.com/support/DTC.pdf
P1555 Cylinder 5 Injector Circuit Range/Performance
C1503 Right Front Isolation Diode ABS (which I found in this list)
https://www.ford-trucks.com/forums/4...self-test.html
Old Mar 15, 2011 | 01:21 PM
bismic's Avatar
bismic
First step (IMO) is verify the batteries are fully functional - load test them individually. Then check FICM voltage.
The injector codes indicate a short or defective injector coil. It could also be a FICM issue or a harness issue.
Old Mar 15, 2011 | 03:43 PM
m350's Avatar
m350
OK thanks Guys thanks for the info,,,last year I replaced both batteries, and this winter with all the plowing,,(in January for us) I have replaced the Alternator with a 170 Amp one (supossedly) with smaller pulley,,to help out the reverse chatter after lifting the plow,,it did seem to help,,and have had No issue's until today.
I will check out the Batteries, I will have to read up on How to check the FICM voltage,,,I have seen it on here,,,Just need to brush up on the Procedure ! Any Hints on this ?
Old Mar 15, 2011 | 03:50 PM
npccpartsman's Avatar
npccpartsman
Check the injector harness and plugs for 1 and 5 but I suspect your FICM is or has failed.
onGlue
Oct 5, 2010 09:52 PM
Brother Les
Jul 19, 2010 01:44 PM
amsk8er1983
Jul 30, 2009 07:12 AM
SOB Racing
Jun 12, 2009 07:06 PM
Gil Chesterton
19
Jan 20, 2005 07:14 PM
