Sponsored by: Auxito
header clamps
Old Mar 14, 2011 | 06:57 PM
dixiestripes351's Avatar
dixiestripes351
header clamps
puttin some long tube headers on my 02 f150 but the headers dont have bolt on flanges to bold to the existing exhaust, they are just slip on. i would like to be able to take the headers if need to with out haveing the grind the welds off or cutting the pipe. is there a way to put a flange on it or something like that? i was thankin just regular exhaust clamps but the exhaust shop said the would loosin up from the vibrations.
Old Mar 15, 2011 | 03:01 PM
phil6608's Avatar
phil6608
As long as you get a good amount of pipe slid into the header,you can use a band clamp like this. Don't use a regular clamp.
Dynomax Performance 33226 - Walker Lap-Joint Band Clamps - Overview - SummitRacing.com
After they have it tighten up good, tell them to double nut it so it locks good. It should not vibrate loos then.
Or,
you could weld flanges onto the header and the pipe. Then bolt together with a gasket in between.
Also be sure to double nut the flange bolts.
Old Mar 21, 2011 | 06:59 PM
dixiestripes351
thanks i found some 3 bolt collector flange reducers i can use but my question is that my truck has 4 o2 sensors. the headers i got one o2 sensor bung each. the 3 bolt collector flanges also have an o2 sensor bung. so dose it matter how far apart the o2 sensors are?
Old Mar 21, 2011 | 07:10 PM
phil6608's Avatar
phil6608
You need one 02 before the cat and one 02 after the catalytic converter.On each side.
Are you going to rune all 4 stock cats? or just 2 or what?
Old Mar 21, 2011 | 07:26 PM
phil6608's Avatar
phil6608
Put one in the header and the other one behind the last cat.
Old Mar 22, 2011 | 05:54 PM
dixiestripes351
im gettin rid of the 2 resistors and the stock cats. puttin in 2 universal high flow cats. so put the other set of o2 after them?
Old Mar 22, 2011 | 06:32 PM
phil6608's Avatar
phil6608
You don't have any resonators.
You have 4 cats.
I have mine set up like your talking about,just headers and one high flow cat on each side.
Put the downstream o2s as close as you can behind the cat.
Old Mar 23, 2011 | 08:46 AM
KhanTyranitar's Avatar
KhanTyranitar
The problem is, you are trying to gain maximum performance, just be advised that most high flow cats are not, and most will offer no benefits over the stock ones. Some are a little louder because they are smaller, but they do not flow correctly. When you select a high flow cat, do some research in advance to find out what is what.
Also be advised that if your clamp leaks, it can trigger codes and produce incorrect sensor readings.
Old Mar 23, 2011 | 05:36 PM
dixiestripes351
ok thnaks i will have to find some 3 bold flanges with out the o2 bungs in em so i can get them closer to the cat.
Old Apr 14, 2011 | 05:12 PM
dixiestripes351
im ready to put my headers in this weekend. but i have to dive the truck to the exhaust shop to get the rest of the piping done. will it harm my truck at all if i run open headers for a few miles? i know the check engine light will come on cuz of the o2 sensors
Old Apr 14, 2011 | 05:51 PM
phil6608's Avatar
phil6608
No, not a problem to do that.
67-F100
Jan 3, 2013 10:16 AM
Forestgnome
Nov 26, 2010 02:57 PM
russell56443
Mar 25, 2005 03:55 PM
snowmobilerfreak
Exhaust Systems
Aug 29, 2004 11:41 AM
cleanLX
42
Nov 3, 2003 10:25 PM
