Sponsored by: Real Truck
4r100 question.
Old Mar 12, 2011 | 11:46 PM
powerstrokeforever's Avatar
powerstrokeforever
4r100 question.
I have an 02 F350 with a 7.3 diesel and 4r100. I want to know if there is a way I can keep the trans from shifting out of OD when I get into the throttle? This engine has enough torque to keep it in od longer and get better fuel economy. Low rpm shifting really helps fuel economy. Wish I could do it in all gears ; )
Old Mar 13, 2011 | 05:51 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
You need a custom tune to do that. The shifting is controlled by the PCM, so changing the PCM's program is how you modify when it shifts.
Old Mar 13, 2011 | 11:48 AM
BillyBob69's Avatar
BillyBob69
What Mark said. Or you can take it to a GOOD tranny shop and see if they will change it for you. OR.... (always onther opinion), you can send your PCM in to someone like DP-Tuner and they will reprogram your PCM for you.
kountzecobra
18
Jan 7, 2022 01:48 PM
02sd
Sep 17, 2014 09:00 PM
SpartanDieselTech
Sep 23, 2007 10:38 PM
skigalini
Dec 22, 2003 08:01 AM
Colossus
Jun 13, 2003 11:03 PM
