6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Coolant level
Old May 6, 2012 | 07:11 PM
  #61
RM2738's Avatar
RM2738
Originally Posted by TIRE FRYER
Well, I was doing great with maintaining coolant level. Got under my truck the other day to do some pre-summer inspection and found coolant starting to leak from the lower hose/engine. Just got it back from the dealer again, got 50k miles now, keep you guys updated on the inspections.
Don't be surprised if its the upper hose. (Hope it's the upper). I just replaced mine. Was dripping just right from the upper onto the lower which made it appear to be the lower.
Old May 6, 2012 | 08:16 PM
  #62
senix's Avatar
senix
usually the upper. here is mine from last summer
Old May 6, 2012 | 08:22 PM
  #63
RM2738's Avatar
RM2738
That's what the SA said. Not too man lowers but there is a fresh post with some members that just had lowers so I bit my tongue on saying that.
Old May 6, 2012 | 11:22 PM
  #64
TIRE FRYER's Avatar
TIRE FRYER
Ill check the paperwork again, I think they put new o-rings at the dealership. Good thing is, I haven't had to do a coolant flush since my coolant seems to be replaced every year or so due to coolant leaks. Then again, same deal with my Cummins
Old May 7, 2012 | 06:20 AM
  #65
RM2738's Avatar
RM2738
Do you have the newer hose design? I think they have multiple o-rings at each connection.
Old May 9, 2012 | 10:54 AM
  #66
golfingnut's Avatar
golfingnut
What is the coolant capacity and is there a better alternative to the Ford coolant? Will be deleting my EGR and replacing both rad hoses, due to weeping coolant.
thanks
Dave
Old May 11, 2012 | 09:10 PM
  #67
pmyers's Avatar
pmyers
4wd High
After reading this post I think I might replace all the o-rings pro-actively when I flush the cooling system this fall.
deezdrama
Aug 21, 2016 02:33 PM
F1snob
Mar 13, 2016 10:11 AM
joe60
Jan 28, 2016 02:57 AM
Montync
Oct 7, 2015 02:39 PM
fred_79f250
Feb 6, 2012 09:37 PM
