Drive shaft brake
Old Mar 10, 2011 | 10:34 AM
Talyn's Avatar
Talyn
Drive shaft brake
Anyone have one they took off?
Thoughts?
If it works fine for a parking brake, that makes for easy rear disk upgrade.
Old Mar 10, 2011 | 10:44 AM
Neal 97 250's Avatar
Neal 97 250
Huh?
What does parking brake and rear disc have to do with you breaking a driveshaft.
I have one that came off of a 460 F-350.
Old Mar 10, 2011 | 10:47 AM
Talyn's Avatar
Talyn
Ooops. i did do the brake break thing didn't i. Damit.
Old Mar 10, 2011 | 10:49 AM
Talyn's Avatar
Talyn
Getting sick of the crappy drums in the back. Its bad in the winter here with the water and salt.
With the Drive shaft Brake I can use it as a P-brake, and not have to worry about what calipers I put on the rear.
I wont even touch the parking brake in the winter.
To afriad of it freezing up.
Old Mar 10, 2011 | 10:50 AM
Neal 97 250
Oh I see. You want the brake on the drive shaft.
Sorry I don't have one of those.
Old Mar 10, 2011 | 10:55 AM
Talyn's Avatar
Talyn
So your saying you for some reason kept a broken 460 drive shaft?
Old Mar 10, 2011 | 06:52 PM
strokin'_tatsch's Avatar
strokin'_tatsch
I'm assuming he has a good 460 driveshaft.. In case you broke your driveshaft.. All this brake, break, broke, whatever. Confusing me. LOL
Old Mar 10, 2011 | 07:03 PM
Talyn's Avatar
Talyn
I fixed it, nothing to be confused about.
Take a deep breath. haha.
Old Mar 10, 2011 | 11:44 PM
oldbird1965's Avatar
oldbird1965
My 50 Plymouth has one on the driveshaft! My disk brake conversion has emergency brake cables that work good.
Old Mar 11, 2011 | 05:49 AM
DZL JIM's Avatar
DZL JIM
PREMIUM SPONSOR
Those shaft brakes are crappy at best, and stupid expensive IF you can find one. Like $1000 - $1500.
Not worth it.
There's a kit out now for the OBS to use SD rear hubs, rotors and calipers to get the job done right.
It's $$$ but it's the best way to go.
__________________
'96 7.3 F-350 Reg Cab 4x4 - bought new.
'04 6.0 E-350 custom 4x4
'08 6.4 F-550 Reg Cab 6 spd 4x4
'17 6.7 F-250 KR ccsb 4x4
Old Mar 11, 2011 | 08:10 AM
dizzyfingers03's Avatar
dizzyfingers03
Not worth it.
X2 on that! I was gonna say the same thing about drive shaft parking brakes.
We have a W5500 at work that has one and it SUCKS. It can't even hold the truck empty on a slight hill (and yes, the mechanic was there last week, it's still well adjusted). The extra gear reduction in the diff is what makes the p-brake effective at the wheel.
The second problem is that you CANNOT use the drive-shaft brake as a secondary emergency braking system. I'm not sure why, but every truck I've seen with one, had a big yellow sticker indicating that in the cab.
Now, to look up this magical kit that uses SD rear hubs on my OBS
Old Mar 11, 2011 | 08:14 AM
Talyn's Avatar
Talyn
If i'm going to dink around and change lug patterns, i'm just going to swap new axles.
Was a thought, thats all. =)
But now that you mention the gear ratio's and such, that makes sense.
Old Mar 11, 2011 | 08:32 AM
Butch(OH)'s Avatar
Butch(OH)
Not worth it.
Hey now Jim! Your talking 'bout my baby.
I love my driveshaft parking brake,, and my once piece I-beam front axle, and my ultra cool 10 lug wheels.
You cant just bolt it to your truck. The brake uses a special output housing that requires the same tranny case used in 4WD applications. A person with a 2WD could switch trans case to a 4WD unit and remove the transfer case and attach the brake. If your truck is 4WD then I dont know as I am not familiar enough with that set up to say.
Bat4x4
May 7, 2021 11:12 AM
Outerlimits36
Feb 27, 2017 06:16 PM
wvbogger
Jan 31, 2008 01:09 PM
Hiexcur
Dec 13, 2002 09:07 AM
BigMattXXL
Oct 12, 2002 06:59 AM
