Could a brake be installed at the transfer case or pinion and be used along with the wheel brakes to increase braking power? I see many kits for parking brakes mounted in these areas but never as a brake hooked in with the wheel brakes.
The biggest problem with a pinion style brake is that the driveshaft spins at such a fast rate , compared to the wheels, that the single brake overheats. I understand that you want to use this along with wheel brakes, but this will still be a heat problem, and if driven on the strret,will wear out pads rapidly.
The more gear you run, the greater the rpm af the shaft, and the greater the heat during a stop.
That is why they are using them as parking brakes.
Best choice is to upgrade the brakes with larger calipers, and larger rotos if you have the wheel clearance.
