Replacing cab mounts by JUST jacking cab
Old Mar 12, 2011 | 10:39 PM
wyoming4x4's Avatar
wyoming4x4
nice work!
lmc are thin and won't ever use again. also didn't fit well at all. dissapointed on the purchase.
Old Mar 13, 2011 | 08:21 PM
Melbatoast's Avatar
Melbatoast
I also have this problem. I don't see the cab mounts in LMC though. I am not to worried about high quality as this will be a mud truck. And be built for purpose not for pretty. And not to last a lifetime. Those mounts that other poster made are awfully sturdy. Good job on that build.
Old Mar 13, 2011 | 09:33 PM
73 ford guy's Avatar
73 ford guy
If it's a mud truck then you should worry about it even more! All that bouncing will eventually crush the thin mount. At the very least replate the bottom of the replacement cab corners with some minimum 1/8 plate on the bottom and wrapping a couple inches up the 4 sides to prevent problems..
Do what you want but I've done my share of "mudding" too man...
Old Mar 13, 2011 | 09:46 PM
Melbatoast's Avatar
Melbatoast
On that note you are right. It would suck to have the cab collapse onto the tires after a rough hill or creek bank climb. Or the ordinary 2 ft jump.
Old Mar 13, 2011 | 09:47 PM
Melbatoast's Avatar
Melbatoast
And by the way what size are you're tires?
Old Mar 13, 2011 | 10:05 PM
73 ford guy
They're 44" swampers. Just saying you'll regret it when it fails. It really is the weakest spot on the whole truck body. I went through the replacement cab corners flattening them, ripping them and w/e. I even tried to replate the bottom but didn't go with a heavy enough gauge. I like to build things to overkill after it fails just like every part on my entire truck from axles,driveshafts,steering to every bolt grade 8.
This was my old cab corner on my replacement cab. Not really 4x4 worthy
Old Mar 13, 2011 | 10:10 PM
Melbatoast's Avatar
Melbatoast
I see know. I have rebuilt a few ol chevys. And made them crazy *** offroad ready and have never seen Anything like this. It seems I am dealing with a different animal now. It appears to be a real truck.
Old Mar 13, 2011 | 10:17 PM
Melbatoast's Avatar
Melbatoast
I am running 38.5s on mine. And need the cab to be right to make them clear good. I figured it was weak springs and bad shocks. It wasn't, I did all that today. The worst part was the Center top bolt for the springs I swear they were original. I gave up 2 mins in and torched 'em out. And made brackets to hold the spring in from plate steel.
The passenger side is 2 inches lower then the driver side. I jacked up the cab and it straightened right out.
Old Mar 14, 2011 | 10:07 AM
Peteg5's Avatar
Peteg5
Great info on the cab mounts, thanks all for the input.
GN1220
Dec 7, 2024 10:25 PM
ExPACamper
23
May 25, 2022 08:10 PM
SchwartzStock
Apr 29, 2016 08:55 PM
norvillebob
43
Jul 31, 2012 03:14 PM
z1121jack
Jun 22, 2010 06:58 AM
