Texan needs an engine.
Old Mar 12, 2011 | 10:46 PM
Bledsoe76's Avatar
Bledsoe76
The 429 in my 78 F250 met its demise today. My mechanic said the knock in my engine was my crank. My float has been leaking fuel into the engine for probably years ( I bought the truck a month ago) and burned out the bottom half of my engine. Im stuck now looking for another engine. My question is.....351C vs 302. Many friends say 302 can't be beat. Any suggestions? Any texans sitting on an engine? Post any info here. If you are in Texas and have an engine email me. Bledsoe76@sbcglobal.net please.
Old Mar 12, 2011 | 10:55 PM
Ziegelsteinfaust's Avatar
Ziegelsteinfaust
I think the 302 will provide the best mileage for the least amount of work, but the 351C would be the best bet if you wanna use you truck as a F250.
Why not re-build your 429? Or jump it up to 460 as you already have over 1/2 the stuff, and swaps in Fords are not that fun.
If you swap engines you need to need to either get new stands or in some cases move your stands back or forward. Plus the transmission, and all the accesories.
Damn if I don't have an engine, but I am too far to deal.
Old Mar 12, 2011 | 11:14 PM
Jexes23's Avatar
Jexes23
From Dalhart Texas, which is north of Amarillo you can get to the state line of Montana at least an hour faster than you can get to Brownsville Texas. From El Paso Texas You could get to Los Angeles California at least and hour faster than you could get to Orange, Texas.
So yeah I'm in Texas and have 460 I want to get rid of, but that doesn't mean I'm anywhere close to you. Our state is huge.
Old Mar 12, 2011 | 11:20 PM
Bledsoe76's Avatar
Bledsoe76
Wow you are way up there. Im in Hillsboro 60 miles south of Dallas. He says to rebuild the 429 would cost me about $2500. I figured a replace would be ALOT cheaper than that. I personally don't know squat about engines. Thats why im looking for advise. Is that overpriced? He says its gonna need new rings, seals, rods and lots of other (expensive) parts. Is he being lazy or squeezing my wallet? I was thinking 351C since thats what should be in it right? But I can't find one anywhere near me. Figured I would ask here.
Old Mar 12, 2011 | 11:29 PM
Ziegelsteinfaust
I re-built my 460 in my garage for about $2500 with tons of parts. All of which were upgrades over stock.
So if he is going to do it like I did then it would be worth it.
Get a build sheet from him that he would use, and post up what you want from your truck. Then you can get a few opinions on how we have done things.
Old Mar 13, 2011 | 12:29 AM
Sleepy445FE's Avatar
Sleepy445FE
I dont believe the 351C was ever offered in a pickup and was not available after 74. The 351M is the one your thinking of.
Old Mar 13, 2011 | 11:52 AM
78 PEB's Avatar
78 PEB
Price a rebuilt 429 or 460 out from NAPA or some other reputable parts house. Id bet you could buy a long block for less than 2500 and it would have a warranty.You wouldnt have to worry about changing mounts and bellhousing if it's a manual trans or complete trans if its an auto. Swap over your oil pan, valve covers, intake etc and youd be good to go. Oh, and BTW..................get the carb rebuilt while youre at it!!!!!!!! dont want a repeat!!!!!!!!!!! Good luck
Old Mar 13, 2011 | 11:53 AM
Bledsoe76's Avatar
Bledsoe76
I would love to rebuild the 429 in it but I don't have that kind of money. The most I have is about 1500. Im looking for a donor motor but not having any luck. Therefore im looking for a replacement. 302, 351, 460. Would rather put the trucks original back in it. How would I find out what that is?
Old Mar 13, 2011 | 12:08 PM
78 PEB's Avatar
78 PEB
I just looked at Autozone for you.Just for giggles I looked up an '80 460 long block. $1750 with $410 core charge. Has a 3 year warranty. I think thats the way to go, unless you want something high performance. Then youd know what you have. You may get lucky and find a good junkyard motor, or you could end up pulling it 2 or 3 times to get a good one in it. If you plan on keeping the truck for a while Id get the reman.......then you will know.
Old Mar 13, 2011 | 12:12 PM
jim collins's Avatar
jim collins
Post your VIN number it will tell you what you have.Page 8 in LMC catlog will tell you how to figure it out. Or go on line at www.lmctruck.com JIM
Old Mar 13, 2011 | 09:32 PM
Bledsoe76's Avatar
Bledsoe76
Ok. so based on Vin my truck came with a 460. Im looking around now for a replacement. Looks like I might get an engine from Autozone if I can't find another soon.
Old Mar 14, 2011 | 11:06 AM
Poison Oil Racing's Avatar
Poison Oil Racing
I have a 460 that has been machined (+ .030 on the cylinders, + .010/.010 on the rods and mains, new cam bearings installed, sonic tested, etc., etc. I have a receipt.) sitting in my garage waiting for some one to come get it. All you need are some pistons, a cam, a gasket set and you are good to go. I have the rod and main bearings.
The heads would need to be machined, or use your own.
I also have all of the pulleys, brackets, power steering pump, etc., as well.
Located in Montgomery, IL. Asking $800.00, no shipping.
MisfitMetalhead52
Texas Chapter
May 25, 2014 05:43 PM
texan2004
1983 - 2012 Ranger & B-Series
Jul 13, 2005 08:09 AM
F150Texan
Texas Chapter
Jun 27, 2004 06:41 PM
greg58
Texas Chapter
Mar 19, 2002 08:24 PM
